1991 chevy p30 rv chasis 454 - no spark/no fuel
  • mdz320
  • mdz320's Avatar Topic Author
6 years 10 months ago #36196 by mdz320
I've replaced cap and rotor, coil, ignition module, and the pickup coil. 12 volts out of coil post. No Spark. No fuel through the injectors either . Fuses looked good.
6 years 10 months ago #36198 by John Curtis
Replied by John Curtis on topic 1991 chevy p30 rv chasis 454 - no spark/no fuel
Does CEL display for a quick second with initial key on?
if not, check for reference voltage from PCM.
What happens during crank? Does your tach move/bounce at all?
if not, check for injector pulse and do a bypass test to try and fire spark.
Depending on what you have available to test, you can test for voltage on the crank sensor to see if you get any voltage during crank.
I don't think a fuel pressure check is necessary without having spark or injector pulse.
To test injector pulse use a test light on Bat + and backprobe the control wire of the injector. During crank, the light should pulse on and off.
