[FIXED] Ford Mondeo 1997 20L- Baro
9 years 9 months ago - 9 years 9 months ago #4879 by Noah
Let me move this thread to the repair section for you! ;)
Last edit: 9 years 9 months ago by Noah.
The following user(s) said Thank You: Interrupt
9 years 9 months ago - 9 years 9 months ago #4883 by Interrupt
Replied by Interrupt on topic [FIXED] Ford Mondeo 1997 20L- Baro
Sorry I thought it was the repair section?? :oops:
So I've copied and replied to this message with my original questions!!!! :whistle:
Last edit: 9 years 9 months ago by Interrupt.
9 years 9 months ago #4884 by Interrupt
How is baro calculated / which sensor gives baro on the above vehicle(does it have a dedicate sensor or is calculated via a map sensor at ignition on and wide open?)
We at sea level or very close to and this thing is reporting baro of 78Kpa(I believe this pressure relates to an elevation of 1800m)
The car has no fault codes, fuel trims long and short are < 10% (less than). no drop outs of accelerator position sensor and it has the nastiest hesitation/flat spot it is so vicious it is like the ignition is be switched of during acceleration.
Any idea of a starting point for this job would be great.
9 years 9 months ago #4885 by Tyler
Replied by Tyler on topic [FIXED] Ford Mondeo 1997 20L- Baro
Doing research on this one will be tough, since they don't sell the Mondeo in the US :( BUT, Wikipedia tells me that the two engines the '97 Mondeo came with are both MAF systems (at least on US model vehicles).
That means it's possible that there is no BARO sensor, and that the BARO reading is actually calculated based off the MAF reading at high loads. Whenever we see a skewed BARO reading on a Ford, we can usually figure there's a MAF problem, or a volumetric efficiency problem.
The trouble is that the symptom you're describing doesn't really sound like a MAF issue to me. :unsure: More like a cam/crank sensor dropping out intermittently. Unless the MAF signal is dropping out completely, and I'd expect to see a MAF code for that.
Any scan data available during the hesitation/flat spot? Maybe we can spot a good direction to go in from that.
9 years 9 months ago - 9 years 9 months ago #4889 by Interrupt
No I didn't save any because the only thing that stood out was that crazy baro reading!! , I can try get some any particular pids ?
9 years 9 months ago - 9 years 9 months ago #4937 by Interrupt
Just thought I'd report back and let you know this on is fixed....turns out the good old visual did the trick we noticed the wire insulation on almost ever sensor and injector has aged/weathered and bearing copper. The TPS wiring was shorting under acceleration. After a dab of silicon around the exposed copper to insulate wires seems to have stop the fault. Why no fault code for this .....why the crazy baro reading....I don't know but the car is running great now!!>>>>>??
9 years 9 months ago #4942 by Noah
Replied by Noah on topic [FIXED] Ford Mondeo 1997 20L- Baro
Can't argue with results!
Time to create page: 0.326 seconds
