P0106 with low manifold vacuum
- Theshorefix
- Thank you received: 2
- Cheryl
- Thank you received: 215
- Theshorefix
- Theshorefix
- guafa
- Thank you received: 80
You can also check O2 upstream sensor activity, so you can rule out a fuel delivery issue.
At wot, 02 voltage should be rich all the time.
Edit: On the road
- guafa
The final pressure in a compression test, depends on baro pressure (or altitude).
- Theshorefix
- Matts Auto
- Thank you received: 28
- Denisf
- Thank you received: 7
- guafa
To discard valve timing issue, you can unplug valve actuators.
You can also perform again compression test with valve actuators unppluged.
105 to 115 psi seems to me a low pressure, but if you live like me at 3200 m/(8000 feet), that could be normal. What is suspicious is the difference between cylinders, but again leak down test contradics a mechanical issue.
- guafa
That would be great to know the ones (fuel trims) which match with the lack of power.
Denisf wrote: I really hope you don't have to deal with timing chains on that one.
You're not kidding!
- Theshorefix
- Theshorefix
- Theshorefix
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
When you get it back together... please post the idle timing.
