Nissan X Trail 2019 4 cylinder
- abe1204
- Thank you received: 5
6 years 9 months ago #36852
by abe1204
Nissan X Trail 2019 4 cylinder was created by abe1204
undefined hi ,guys anyone help with a nissan X trail no comm no start no crank. and steering lock 2019 model ,this happen after a removal of cylinder head and after Put back all components it start only once and and try again no nothing wont crank, we check battery ,cable and grounds fine ,, anybody can knw about this proboem...Thank you ...
- Cheryl
- Thank you received: 215
6 years 9 months ago #36853
by Cheryl
Replied by Cheryl on topic Nissan X Trail 2019 4 cylinder
I don’t think this car is in the USA. But does the check engine light illuminate during key on or engine cranking? Check for 5 volts at the maf or throttle body. Can you communicate with any other modules besides the engine control module? But your probably going to have to check powers and grounds at the engine control module see what’s missing.
- abe1204
6 years 9 months ago #36913
by abe1204
Replied by abe1204 on topic Nissan X Trail 2019 4 cylinder
Thanks cheryl its a push button .type .no lights on dash board .when i hit the button.remote is working .
- Tutti57
- Thank you received: 254
6 years 9 months ago #36914
by Tutti57
Replied by Tutti57 on topic Re:Nissan X Trail 2019 4 cylinder
What was the reason for the cylinder head replacement?
Make sure the PCM connectors are clicked in all the way and check powers and grounds on it like Cheryl mentioned.
Did it start that one time then turn right off?
Nissan Technician
Nissan Technician
- abe1204
6 years 9 months ago #36948
by abe1204
Replied by abe1204 on topic Re:Nissan X Trail 2019 4 cylinde
costumer complaint for overheating and the Cylinder was damaged so they replaced by other Mechanic after all According to them its starts once and when they completely put back all components The car was not able to start , no lghts in the dash board,, the computer does not communicate to the Scan tools , and also i tried my best to hooked a scanner it does not communicate , so I check the grounds and all battery connection Ignition feeds are all good .., maybe it needw a Nissan Tech To ths kind of problem ,or maybe its needs some program to make it start,,Or it might be there is something wrong in the module like bdy conrrol module.or it needs a nissan tools .. Tomorrow Nissan Tech would come to check this car,,, ill give you info when this car is fixed or not..Thank you mate Godbless!!!
