03 nissan exterra 3.3 room lamp no power.
  • gilbert
  • gilbert's Avatar Topic Author
6 years 9 months ago #37169 by gilbert
God bless you my brothers and sisters.
I got this 03 Exterra with no room lamp I checked for power on the red/grn wire at the bulb and nothing. So I check the fuses and they are good checked continuity from fuse 26 to red/grn wire on bulb connector and there is continuity but no power. Can anybody tell me why there is continuity but no power thank you.
6 years 9 months ago #37170 by Cheryl
Replied by Cheryl on topic 03 nissan exterra 3.3 room lamp no power.
Continuity is only testing for an open and nothing more. It’s not a load test. You could have 1 single strand of copper holding the wire together but it can’t carry a load. So if your sure there isn’t a short to ground on that wire I’d apply power to one end of the wire and use a headlight bulb to check for power or a test light just not an led one
The following user(s) said Thank You: Noah, gilbert
  • gilbert
6 years 9 months ago #37172 by gilbert
Replied by gilbert on topic 03 nissan exterra 3.3 room lamp no power.
Hey Cheryl thak you for the info. that is right 1 strand won't carry a load. Ok let me tell you what I did I jumped a fused wire to the plug and it worked. Does this mean that there is a brake in the wire? Should I follow the wire from end to end or is there a better way?
Thank you.
6 years 9 months ago #37173 by Cheryl
Any connections between fuse box and dome light?
  • gilbert
6 years 9 months ago #37174 by gilbert
The wire diagram shows that it is a straight shot from the fuse the only other wire that it powers is the map light. When I put power straight from the fuse both lights turned on.
Time to create page: 0.265 seconds
