Hyundai Immobilizer No Crank No Start
  • tonybushmin
  • tonybushmin's Avatar Topic Author
6 years 8 months ago - 6 years 8 months ago #37383 by tonybushmin
Hyundai Immobilizer No Crank No Start was created by tonybushmin
2014 Hyundai Sonata 2.4L came in on the hook, motor locked up no oil (second time for this car), replace with a junkyard unit and left the junkyard harness, replaced started because it was burned up when the customer tried to crank the engine over, now we have a no start no crank condition. I can jump the relay and crank the engine, I get control at the starter but no ground is present for the starter relay. Second I can crank with the key on and no spark. Scanned for codes and I get a pending code P1690 - Immobilizer Smartra no response. Tried to enter the immobilizer module through the scanner and it throws a no comm. So check power and ground at immobilizer?
Last edit: 6 years 8 months ago by tonybushmin.
  • tonybushmin
6 years 8 months ago #37384 by tonybushmin
Replied by tonybushmin on topic Hyundai Immobilizer No Crank No Start
Gonna swap the harness first thing tomorrow. I just realized thats probably my issue and I should of done that from the start lol.
6 years 8 months ago - 6 years 8 months ago #37388 by Patrickreaves
Replied by Patrickreaves on topic Hyundai Immobilizer No Crank No Start
sounds like you are missing control (-) at the relay. if you can energize the relay by providing the missing (-control) on the relay and this turns the starter on at the same time , then its definitely missing it. or are you putting 12 volts directly on the load side of the relay to energize the starter? either way, it sounds like its missing control on the starter relay.( this is normal with an anti theft issue)
my 2005 f150 also disables starter control, and injection pulse, and fuel pump, if there is an anti theft issue. The no comms suggests that things aren't talking. If the ignition key,( chip) is not being read / cleared as correct key, when you crank the key, then the pcm will recognize that you are trying to start it with out the correct key. it will then go into ani-theft mode and disable the starter and injection . when this happens it will never apply control on the starter relay during cranking.
The communication issue needs to be addressed first. Get it up and running so it can read the key , and it may need nothing else.
Last edit: 6 years 8 months ago by Patrickreaves.
  • tonybushmin
6 years 8 months ago #37389 by tonybushmin
Patrickreaves wrote: sounds like you are missing control (-) at the relay. if you can energize the relay by providing the missing (-control) on the relay and turn the starter on, then its definitely missing it. or are you putting 12 volts directly on the load side of the relay? either way that you are doing it ,
my 2005 f150 also disables starter control, and injection pulse, and fuel pump, if there is an anti theft issue. The no comms suggests there that things aren't talking. If the ignition key ( chip) is not being read / cleared when you crank the key it will never have control on the starter relay. you need to start with the communication issue first . get it up and running so it can read the key , and it may need nothing else.
Gonna try swapping the harness in case that the donor engine was not equipped with keyless entry and other features that the original has, therefor the immobilizer and ecu do not communicate together.
6 years 8 months ago - 6 years 8 months ago #37390 by Patrickreaves
I honestly don't see how an engine, that is removed from a none key-less entry donor vehicle, and installed into a key-less entry vehichle would have any effect on the anti theft issue. I just dont see the connection between the engine/harness, and the anti theft programming.(but i could be wrong) Maybe some one else knows more and can shed light on this.
  • tonybushmin
6 years 8 months ago #37440 by tonybushmin
Patrickreaves wrote: I honestly don't see how an engine, that is removed from a none key-less entry donor vehicle, and installed into a key-less entry vehichle would have any effect on the anti theft issue. I just dont see the connection between the engine/harness, and the anti theft programming.(but i could be wrong) Maybe some one else knows more and can shed light on this.
www.hsguide.net/description_and_operation-639.html
Harness fixed it! Not sure why it would make a difference but I know that the engine and immobilizer communicate. A vehicle with none keyless car still has an immobilizer though right?
6 years 8 months ago #37442 by Patrickreaves
Its good that the harness was the right call, (never would have thought it) both cars should have a similar anti theft system.
just thinking out loud here,
in 1st scenario pcm is not communicating with anti theft components , and will not start.
in 2nd scenario, same pcm with new harness that deleted keyless entry component, and it starts
one would think that in either scenario, the pcm is not seeing what it wants to see.
in scenario #1 because the new engine was missing a component that cant be plugged in. = a no com
in scenario #2 because new harness deletes the components circuit all together. this should still = a no com, because the pcm would still not see the component.
whether the component is unplugged/missing , or if you delete that components harness, the pcm is not seeing the component in either case.
maybe someone can explain this to both of us , thanks
  • tonybushmin
6 years 8 months ago #37449 by tonybushmin
Patrickreaves wrote: Its good that the harness was the right call, (never would have thought it) both cars should have a similar anti theft system.
I believe my situation is the second scenario. The code from the pcm states no response from smartra which means that it got no response with key code encryption thingy. Read the link I pasted above it gives a very good overview of the Hyundai anti theft system. After reading that I really thought about that harness
6 years 8 months ago - 6 years 8 months ago #37453 by Patrickreaves
6 years 8 months ago - 6 years 8 months ago #37454 by Patrickreaves
6 years 8 months ago #37469 by Southernfiy
Replied by Southernfiy on topic Hyundai Immobilizer No Crank No Start
I have 05 Tucson the immobilized was direct below the steering wheel. The chip was turned around backwards. It then cranked and started, runs great.
