2006 dodge ram 5.7. P0300 misfire and a p0174 1/2. Lean code
  • gerber
  • gerber's Avatar Topic Author
6 years 8 months ago - 6 years 8 months ago #37418 by gerber
2006 dodge ram. 5.7. I check fuel pressure at idle and is at 60psi
But when i press de gas. Fuel drops to 30 psi and make a backfire.
Long fuel trims at 30
And short fuel trims at -1.2
Its a new fuel pump in there
And this sistem dont have a return line. Everything is in the pump. The only thing that i see is the throttle body acting crazy. Drop voltage. But a dont have any code. For it . VĂ­deo below
Any help will be appreciated
Last edit: 6 years 8 months ago by gerber. Reason: Forgot a video
6 years 8 months ago #37419 by Tyler
Either your new pump is junk, or you have some kind of voltage drop in the pump circuit. ;) If you have an amp probe, you can measure pump current to check for a voltage drop concern. Otherwise, you'll need to get to the pump connector.
You can do direct voltage measurements with the pump plugged in (if possible), or unplug the connector and substitute a heavy load. Two headlamp bulbs would work. If you have power and ground, your new pump is bad. If you find the bulbs won't light brightly, or you find excessive voltage drop, pursue the offending circuit.
  • gerber
6 years 8 months ago - 6 years 8 months ago #37421 by gerber
Do yo think the throttle body has to do something with this problem. Because i see voltage drop app 2 and i know this voltage drop is not right first picture is without press the pedal. And secound picture is at wot.
  • gerber
6 years 8 months ago #37423 by gerber
And yes idid check the current with the old fuel pump. And the new fuel pump
6 years 8 months ago #37424 by Tyler
You only see the dropouts on APP 2, right? I'm pretty sure you're looking at a PCM circuit fault detection strategy. ;) It's intentional, weird as it sounds. The PCM will pulse APP 2 to ground and look for the same pulsing in APP 1. It's there to check for shorts between the two circuits.
If you were to scope the same circuit, you'd see the pulsing to ground is actually far more frequent. It only looks that way on the scanner because of it's limited data rate.
So the short answer is, no. :silly: Normal condition.
6 years 8 months ago #37425 by Tyler
I can't see the scale on your scope capture. :( Looks good from what I can see. If it's in the 7-10 amp range and stays there during a WOT snap, you're done. Pump time (again).
  • gerber
6 years 8 months ago - 6 years 8 months ago #37426 by gerber
But 2. Pumps doing the same thing. ?
Last edit: 6 years 8 months ago by gerber. Reason: Not spelling right
6 years 8 months ago #37427 by Tyler
gerber wrote: But 2. Pumps doing the same thing. ?
Any kinked fuel lines? :huh: Debris at the bottom of the fuel tank? That's about the only thing I can think of.
  • gerber
6 years 8 months ago #37430 by gerber
I just i stall another pump because has warranty. But still the same .
At idle works at 60. But at (wot) drops
To 30
6 years 8 months ago #37431 by Tyler
Are you replacing just the pump itself? Or the pump assembly?
If you've been getting assemblies, and power/ground at the pump is solid, then the new pumps don't have any excuses. :lol: Switch brands if you have to.
  • gerber
6 years 8 months ago #37432 by gerber
Its a new assembly .
  • gerber
6 years 8 months ago #37433 by gerber
App 1. is not doing stay in a parallel line when i press the gas pedal
6 years 8 months ago #37434 by Tyler
Look at you with your yellow Snappy 18V. B)
If you want confirmation of weak/bad pumps, you can also deadhead the pump by installing a pressure gauge directly into the fuel line. With the pump running, the pressure should exceed 100 PSI. You can also do this at the pump itself. If it won't go that high, the pump is junk.
  • gerber
6 years 8 months ago #37436 by gerber
Lol about the 18v. I just go it yesterday. My friend need a oil pan gasket replaced on a jeep wrangler. And he pay me with that. Impact gun Comes with 2 batteries and charger .
Im going to take it look the fuel lines and try that in the fuel pump
  • gerber
6 years 8 months ago #37439 by gerber
I think i find the problem look at the picture. Some one boosted the line qnd twist.
  • gerber
6 years 8 months ago #37443 by gerber
Thank you for all you help
6 years 8 months ago #37447 by Tyler
gerber wrote: I think i find the problem look at the picture. Some one boosted the line qnd twist.
I think you're onto something. B) Had the pump been changed before you got to it?
  • gerber
6 years 8 months ago #37466 by gerber
Yes some work on it before me. That was the problem
6 years 8 months ago #37471 by Patrickreaves
Tyler? are you saying to attach the gauge so that it blocks the fuel off,?
  • gerber
6 years 8 months ago #37498 by gerber
Did you saw the picture ?
