2013 bmw 328i
  • dfends@hotmail.com
  • dfends@hotmail.com's Avatar Topic Author
6 years 8 months ago #37420 by dfends@hotmail.com
2013 bmw 328i was created by dfends@hotmail.com
hello everyone
i have 2013 bmw 328i with the n20 engine
it a no start and i have code 130e20 cam shaft offset code i have checked the wiring good gound and 5 volt signal and 4.85 on third wire . on live data i can see the exhaust cam signal but i cannot see and intake cam signal i replaced the sensor with a known good sensor and check reluctor and is good im not sure if the engine has to be running to see intake signal any help would be appreciated .
6 years 8 months ago - 6 years 8 months ago #37464 by tech25
Replied by tech25 on topic 2013 bmw 328i
hey there, that code appears to be for the intake camshaft angle offset out of range compared to the crankshaft.
the camshaft sensor is a hall effect sensor so the engine would need to be running.
you can either replace the intake vanos solenoid actuator, or mechanically check timing.
i would probably replace solenoid first and retest.
Last edit: 6 years 8 months ago by tech25.
