Brake question 02 Ford mustang
- Tsavory
- Thank you received: 2
6 years 8 months ago #37610
by Tsavory
Brake question 02 Ford mustang was created by Tsavory
I know it's not really electrical diagnostics but I've got an 02 Ford mustang that locks the brakes once you push them. New caliper new lines disconnect all your lines it's still locked up
Wiggle your rotor just a little bit rolls free with or without lines attached.
I would call bad calipers but both sides both New?
6 years 8 months ago #37613
Replied by Andy.MacFadyen on topic Brake question 02 Ford mustang
So to be 100% clear if you crack open a bleed nipple the caliper is still locked until you wiggle the caliper ?
- tech25
- Thank you received: 27
6 years 8 months ago #37615
by tech25
Replied by tech25 on topic Brake question 02 Ford mustang
what if you unplug the abs control module, does it still lock up??
- Tsavory
6 years 8 months ago - 6 years 8 months ago #37627
by Tsavory
Replied by Tsavory on topic Brake question 02 Ford mustang
Yep and once no brake line attached abs is irrelevant. Is it not?
Pads float freely with no caliper, caliper pistons work smoothly both directions, checked that the bracket didn't rub anywhere. Could barely turn the wheel by hand with tire on. Take tire back off still super tight grab opposite side of rotor give just a little jiggle and hub rolls freely
Last edit: 6 years 8 months ago by Tsavory.
- Tsavory
6 years 8 months ago #37629
by Tsavory
Yes bleeder loose line removed still tight till a little jiggle on the rotor.
6 years 8 months ago - 6 years 8 months ago #37630
Replied by Chad on topic Brake question 02 Ford mustang
Is there rust built up on the hub, making the rotor sit cocked?
Last edit: 6 years 8 months ago by Chad.
- Tsavory
6 years 8 months ago #37634
by Tsavory
Nope.
Checked by both visual and put lug spacers and tightened down rotor runs true
6 years 8 months ago #37637
That 100% eliminates anything outside the caliper.
Not unknown for pads to jam in the calipers, this was a common issue on older European Ford's. Check the surfaces on the calipers and pads where the make contact.
The following user(s) said Thank You: Tsavory
- Tsavory
6 years 8 months ago #37665
by Tsavory
We went ahead pulled it all back apart started from scratch everything looked good. It has New pads, (another set of new)calipers, brackets, and hoses. Same thing.
Went ahead took it for a drive temps on rotors never got hot like when it came in 170° cooler same route and braking. It has more power than before. So boss let it go.
Came in with smoked pads and rotors. Replaced them test drove and both sides got hot so I tested the caliper pistons and sliders again.
Caliper pistons flowed freely and with slight pressure so called the line on the one side due to how inexpensive they where boss said just do both. Still got hot so thought maybe just maybe there was a catch in the pistons. Went ahead got the calipers.
I must admit this was one I felt really bad seemed more like a parts cannon than finding the problem.
But spent way to much time on a brake job.
