2003 Hyundai Tiburon V6 - P0171/0174/1166/0133/0153 - 173,000 miles
  • Sure4Thing
  • Sure4Thing's Avatar Topic Author
6 years 8 months ago #37644 by Sure4Thing
Hey All:
Trying to track this annoyance down. I don't notice any lagging, rough idle, or lack of power at all. I thought it was intake manifold gasket but on a cold start I sprayed all around the intake manifold and didn't hear ANY RPM spikes or lows. I also ran some data on the O2 sensors. All of those videos and pictures are below
photos.app.goo.gl/7VXCuz3SY1PVTHy56
Can someone point me in the right direction as to where I should look next. I didnt see any vacuum line cracks or anything like that including on the air intake but ill admit I didn't look super close, its freezing out. When I was looking at the sensor data from Torque, it seemed that 3 of the O2 sensors weren't oscillating and instead were just staying high.
As for the maintenance history, buckle up because I love this story. My first car was an 07 GT limited V6 5 speed (in my profile picture). Loved that car to death. Moved to Maryland, less than 24 hours a guy plows into me, bending the frame, car is totaled. I then bought an 08 GT V6 5 Speed with only 50,000 miles on it for like 5K. It was OK but not near the quality as my 07. At this point I knew NOTHING about cars and was always scared to do my own maintenance. Because I was buying the car out of state, I asked the seller to take it to a shop to have them give it a once over to make sure it would pass inspection / emissions. The shop called and said it would. I drove up to NY from Baltimore and bought the car. Brought it back to MD and went to get it registered, failed emissions (straight piped) and failed safety (steering column). The steering column had a wobble in it and the shop wanted like $500 to tear it down to try and figure out what was wrong. At this point, I grew a pair and was like well **** I can tear it down myself. Long story short, I fixed it from tearing it down with no prior experience which was enthralling. I they started doing little things. Brakes, rotors, wheel bearing, etc.
Anyways, flash forward 2 years. My gym is right next to a mechanics. I saw an 03 tiburon in the parking lot. I saw it there for a month. I asked the shop about it because I wanted to see if maybe I could get parts off of it. They said that they quoted $3000 to the owner to fix it and the owner just left it and took off their plates. I saw an opportunity and filed an ABR (Abandoned Vehicle Request) to VA and 15 days later got the approval to proceed. I then filed an ITA (Intent to Auction). 10 days later, I took the paperwork to the DMV and got the title for the car. I walked into the shop, gave them the $75 that was owed on the car for the diagnostic, got the keys, and the diagnostic report. It needed brakes, calipers, control arms, tie rod ends, front struts, and rotors. I priced it all out for like $400. I took a deep breath and was like, I got this. Its not my daily driver so I can learn this.
I took a weekend and some DIYs and 2 days later got the car inspected and registered and I now drive it daily. I save my 08 for the weekends to keep miles off of it. Anyways TLDR, I don't have ANY maintenance history on this car and have been fixing issues as they pop up.
With that being said, what is the chance that all of the O2 sensors are actually bad? It seems to me that if they are all reading these values that maybe something else is causing that issue. It just seems weird that ALL of them could be bad. I mean it is possible that they are all original O2 sensors but it just doesn't seem likely.
Can anyone provide any insight?
6 years 8 months ago - 6 years 8 months ago #37648 by tech25
hey there, I think you have two problems... it looks like you have a vacuum leak by your long term fuel trims on both banks. or a exhaust leak.
1: assume you dont have a smoke machine... but thats the best way. try to test in the air intake pipe.
also, you may not be getting enough fuel. can you check the fuel pressure?? this car doesnt appear to have a fuel filter, there is a bulletin out stating at high altitudes to replace/update the fuel pump to a stronger pump ( note,, fuel filter is part of the fuel pump assembly )
2: regarding the o2 sensor faults, specifically p0133, and p0153, there is a tsb out to update the ecm software to take care of that. I attached a copy of it for you to read over hopefully you can make some sense, by the ecm IDs if its been done or not.
File Attachment:
File Name: hyundaitsb...2-19.pdf
File Size:1,430 KB
Last edit: 6 years 8 months ago by tech25.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
6 years 8 months ago #37649 by VegasJAK
try to wake up the 02's by 1- pulling a vacuum hose(note voltage movement). Then 2- adding propane (if you have the ability) into the intake(note voltage movement). Does B1S1 and B2S1 start moving... you can also snap the throttle several times in a row and note any response.
Increase the RPM to 2500 and hold... how do the LTFT's respond.
  • Sure4Thing
6 years 8 months ago #37691 by Sure4Thing
I was looking at getting one of the paint can smoke machines, I was just putting it off due to it being cold out. Am I able to update the ECM myself? I don't believe I can. All I have is an MX+ unit which I don't think gives me that functionality.
Looks like I have 2 areas going forward. Get a smoke machine on there and then adding propane and get the results back to yall.
  • Sure4Thing
6 years 8 months ago #37692 by Sure4Thing
scannerjohn wrote: try to wake up the 02's by 1- pulling a vacuum hose(note voltage movement). Then 2- adding propane (if you have the ability) into the intake(note voltage movement). Does B1S1 and B2S1 start moving... you can also snap the throttle several times in a row and note any response.
I am guessing that I pull the vacuum hose and then attach propane to where I just removed the hose from correct? I've never heard of "waking up the O2s" before (granted this isn't my forte). How does propane "wake them up?
Ill work on getting the supplies and getting yall back some data.
6 years 8 months ago #37694 by tech25
Sure4Thing wrote: I was looking at getting one of the paint can smoke machines, I was just putting it off due to it being cold out. Am I able to update the ECM myself? I don't believe I can. All I have is an MX+ unit which I don't think gives me that functionality.
did you read the TSB i attached??
I doubt you have that scan tool and card to do the update yourself, however, you might be able to read the engine control module id and compare it to the bulletin to see if the numbers match, ( to determine if its been done or not )
check for air leaks,
also, did you check fuel pressure??
  • VegasJAK
  • VegasJAK's Avatar
6 years 8 months ago #37697 by VegasJAK
you will be doing two separate tests... one is pulling a vacuum line then noting any movement in the trims and voltage of the 02's. put the vacuum line back on then do the second test of adding propane into the intake via the air box and note any change to the trims and voltage of the 02's.
when you have 02's with fixed voltage readings the two tests will show if the 02's are dead or you have a actual lean or rich condition.
the upstream 02's should oscillate from 100 to 900mv if they are narrowband. if they are air fuel (wideband)02's they will have a steady voltage reading... Hyundai is 1.9v. from what I saw, it appears you have the narrowband...
downstream 02's should not oscillate. they should be a steady high voltage, but can fluctuate a little. they are for reporting the health of the catalytic converters.
