P0155
  • autojoe
6 years 8 months ago #37715 by autojoe
P0155 was created by autojoe
2007 saturn vue 3.5. 7 wire 02 sensor. Is this a wide band afr sensor?
6 years 8 months ago - 6 years 8 months ago #37730 by hakachukai
Replied by hakachukai on topic P0155
I can't find any information on 7 wire AFR sensors on the Web in general, but I think that it probably must be a wide band AFR sensor.
This is just an educated guess but I think it is likely that:
2 wires are for the current driven o2 pump
2 wires are for the AFR voltage + and -
2 wires are for the heater
1 wire is for ground
Or I could be completely wrong and it's not an AFR sensor at all
Can you post a detailed picture of it?
Also keep in mind that a P0155 might not be the fault of the sensor.
It could be a blown fuse, broken or shorted wire, bad socket connection.
Last edit: 6 years 8 months ago by hakachukai. Reason: Adding detail
6 years 8 months ago - 6 years 8 months ago #37732 by tech25
Replied by tech25 on topic P0155
yes, this is a wide band o2 sensor,
I only see 6 wires, according to the diagram, directly coming off the o2 ( wide band ) sensor.
1 black/white - heater
2 dark blue - low reference
3 red - reference
4 dark green - input
5 white - pump
6 white - power ( 12v )
Last edit: 6 years 8 months ago by tech25.
The following user(s) said Thank You: aboudi.naddaf, hakachukai
6 years 8 months ago #37734 by hakachukai
When I started searching for 6 wire AF sensors instead of 7, I found this awesome post about wide band AF sensors from this forum:
www.scannerdanner.com/forum/diagnostic-t...-testing-thread.html
It turns out that 7 wire AF sensors do exist. If I understand correctly, they are just basically 5 wire AF sensors with the calibration resistor put on it's own 2 separate pins
6 years 8 months ago #37737 by tech25
hakachukai wrote: When I started searching for 6 wire AF sensors instead of 7, I found this awesome post about wide band AF sensors from this forum:
yes, this car does appear to have the calibration resistor, but is pig tailed/spliced off the o2 sensor. I can only go by the wiring diagram, but it shows only 6 wires coming off the sensor itself. diagram could very well be wrong. would like to see a picture of this car sensor in question to verify for sure
