bidirectional control
  • fahead32
  • fahead32's Avatar Topic Author
6 years 8 months ago #38071 by fahead32
bidirectional control was created by fahead32
U sing a scanner to turn on a radiator fan with bidirectional control , just curious on this question, is the scanner bypassing the coolant sensor to turn the
fan on or it uses the sensor in the process.
I ask because on a 2014 Focus I can command the fan on by using the tool but it would not activate under normal condition.
The cut in temp is 209 deg and the car passes that .I used a aftermarket coolant sensor and that did not solve the issue
Any insight welcomed
6 years 7 months ago #38123 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic bidirectional control
It will be a multi speed fan I would suspect yours like some scantools is testing the highest speed. High speeds generally activate at about 115 to 118c
