[FIXED] longtime lurker/ channel watcher p0154
  • jondoom
  • jondoom's Avatar Topic Author
6 years 8 months ago #38088 by jondoom
I don't know how to mark this as FIXED, but I tested my o2 sensor with a multimeter, for resistance. It was perfect. I then zip tied the o2 sensor further away from the exhaust and put 93 octane with seafoam. I then reseated my air filter just to make sure there wasn't a vacuum leak. Everything seems to be working now!
6 years 8 months ago #38090 by Noah
Replied by Noah on topic longtime lurker/ channel watcher p0154
jondoom wrote: I don't know how to mark this as FIXED
I got you;)
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
6 years 8 months ago #38098 by VegasJAK
Replied by VegasJAK on topic longtime lurker/ channel watcher p0154
you must have a short in the 02 wiring... seafoam and 93 gas is not going to correct the problem. resistance test only shows the 02 heater circuit is working.
you were pulling on the wiring when testing, disconnect the zip tie and see if the problem returns that will be the fix... could be wiring shorts on the exhaust.
