Navigator P0456 & P0442
  • Live2Fish88
  • Live2Fish88's Avatar Topic Author
6 years 7 months ago #38229 by Live2Fish88
Navigator P0456 & P0442 was created by Live2Fish88
Hey guys. 2006 Lincoln navigator with the 5.4L 3V in it. I'm getting a fuel smell upon startup and maybe 5 min in to the ride, more noticeable with the heat on. I have a smoke machine as well as a bi-directional scan tool but I haven't been able to find the leak...I used the smoke machine on it via the purge valve lines on both sides but haven't used it with the scan tool (I just got it not too long ago). What are your thoughts and what's the simplest approach to finding this leak?
6 years 7 months ago #38239 by John Curtis
Replied by John Curtis on topic Navigator P0456 & P0442
I find on a lot of Ford vehicles that the purge sticks intermittently. Just experience. I would start with a vacuum gauge and cycle the purge solenoid on and off and see if you can catch it sticking.
  • Live2Fish88
6 years 7 months ago #38244 by Live2Fish88
Replied by Live2Fish88 on topic Re:Navigator P0456 & P0442
Purge valve wasn't holding vacuum when I originally checked it so I replaced it (about a month ago). But the problem persists.
6 years 7 months ago #38255 by John Curtis
Did you check to see if any charcoal was in the line?
Try an evap purge and canister vent while monitoring in tank pressure. Pretty sure the voltage should be at about 2.5v for fuel pressure sensor. Close canister vent valve, Use purge to pull it into a vacuum till the pressure sensor drops about 1v then turn off the purge valve and see if it continues to build vacuum. Should really help narrow down where your problem is.
  • Live2Fish88
6 years 7 months ago #38276 by Live2Fish88
I'll try that. The part that's got me stumped is the fuel smell under the hood coming into the cabin. Makes me think leak is in engine compartment.
