[FIXED] GMC YUKON 2012 Error code P0601 internal Control Module Memory Fault
- abe1204
- Thank you received: 5
6 years 6 months ago - 6 years 6 months ago #39010
by abe1204
[FIXED] GMC YUKON 2012 Error code P0601 internal Control Module Memory Fault was created by abe1204
Hello guys, I have a code P0601 GmC yukon 2012 Sometimes running suddenly stop and on the Dash appears engine reduce power, what i do so far is cleaning battery and checked Battery Terminal pos, and Engine and Body grounds , and problem still the same,
Last edit: 6 years 6 months ago by Tyler.
6 years 6 months ago #39050
Replied by Tyler on topic GMC YUKON 2012 Error code P0601 internal Control Module Memory Fault
The P0601 is stored in the PCM, correct? And not another module?
If the P0601 is in the PCM, then it sounds like that module is done. :lol: P0601 is almost always the kiss of death. Load test the PCM powers and grounds at the PCM connector itself before pulling the trigger on a new one.
- abe1204
6 years 6 months ago #39052
by abe1204
Replied by abe1204 on topic GMC YUKON 2012 Error code P0601 internal Control Module Memory Fault
Thank You ,Tylor yes It fixed I changed a used one PCM ..
6 years 6 months ago #39055
Nice.
Slapping a [FIXED] on this one.
- abe1204
6 years 6 months ago #39085
by abe1204
Thanks a lot bro,
