FORD FOCUS RS MK2 Engine MALFUNCTION
- Rawat
6 years 6 months ago #39170
by Rawat
FORD FOCUS RS MK2 Engine MALFUNCTION was created by Rawat
Hi,
Intermittent Engine cut on Ford Focus RS MK2 2010. Please can you HELP?. I am from UK.
I tested both can bus Resistance aprrox 60 oms
can scope traces are ok.
THANKS
Fault list:-
===PCM DTC P0087-E2===
Code: P0087 - Fuel Rail/System Pressure - Too Low
Additional Fault Symptom:
- Signal is Below Minimum Threshold
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
===END PCM DTC P0087-E2===
===PCM DTC P2127-62===
Code: P2127 - Throttle/Pedal Position Sensor/Switch E Circuit Low Input
Status:
- Malfunction Indicator Lamp is Off for this DTC
Diagnostic Trouble Code details
APPS 2 input voltage is less than the calibrated limit.
Note: This DTC relates to the APPS.
This DTC may be caused by :
Open circuit in wiring or component
Signal shorted to ground or signal return.
Faulty APP Sensor
===END PCM DTC P2127-62===
===PCM DTC P2125-24===
Code: P2125 - Throttle/Pedal Position Sensor/Switch E Circuit
- There is no change in the signal
Status:
- Previously Set DTC - Not Present at Time of Request
Accelerator Pedal Position Sensor/Switch E Circuit
Open or grounded circuit.
Signal circuit shorted to VBATT.
Faulty APP Sensor
===END PCM DTC P2125-24===
===PCM DTC P0503-A4===
Code: P0503 - VS Sensor A Intermittent/Erratic/High
Status:
===END PCM DTC P0503-A4===
===PCM DTC P1260-21===
Code: P1260 - THEFT Detected, Vehicle Immobilized.
- Signal is Above Maximum Threshold
Status:
===END PCM DTC P1260-21===
===MC DTC U1900-20===
Code: U1900 - CAN communication bus fault
Status:
Module: Message Center
CAN Communication Bus Fault - Receive Error
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END MC DTC U1900-20===
===ABS DTC U0100-A0===
Code: U0100 - Lost communication with the PCM
Status:
Module: Antilock braking system
Note:
===END ABS DTC U0100-A0===
===HCM DTC B2622-30===
Code: B2622 - Auto Leveling ECU Speed Message Invalid / Not Available
Status:
- Test not complete
Module: Headlamp Control Module
CAN Communication Bus Fault (missing messages)
===END HCM DTC B2622-30===
===EPS DTC U0100-20===
Status:
Module: Electronic-Controlled Power Steering
Note:
===END EPS DTC U0100-20===
===IC DTC U1900-20===
Status:
Module: Instrument Cluster
Note:
===END IC DTC U1900-20===
THANKS
Fault list:-
Status:
Status:
Faulty APP Sensor
Status:
Faulty APP Sensor
Status:
Status:
Status:
Note:
Status:
Note:
Status:
- Test not complete
Status:
Note:
Status:
Note:
- derekoliveira
6 years 6 months ago #39175
by derekoliveira
Replied by derekoliveira on topic FORD FOCUS RS MK2 Engine MALFUNCTION
Clear DTCs and check again. Do you have communication with ECM/PCM?
- Rawat
6 years 6 months ago #39180
by Rawat
Replied by Rawat on topic FORD FOCUS RS MK2 Engine MALFUNCTION
HI,
THANKS for you help.
After clearing DTC, only code i get is shown below.
Car will work ok for hours, but when its cuts out then all fault code comes back again.
Code after Clearing DTC:-
===PCM DTC P0087-62===
Status:
===END PCM DTC P0087-62===
===MC DTC None===
Successful DTC reading, no error codes found
===END MC DTC None===
===ABS DTC None===
===END ABS DTC None===
===HCM DTC None===
===END HCM DTC None===
===EPS DTC None===
===END EPS DTC None===
===IC DTC None===
===END IC DTC None===
Status:
===MC DTC None===
===ABS DTC None===
===HCM DTC None===
===EPS DTC None===
===IC DTC None===
- Landroverman1958
- Thank you received: 17
6 years 6 months ago #39184
by Landroverman1958
Replied by Landroverman1958 on topic FORD FOCUS RS MK2 Engine MALFUNCTION
Hi i would check the 5volt reference to your sensors,check out Sy Daiagnostics on u tube,
- Rawat
6 years 6 months ago #39186
by Rawat
THANKS
I DO THAT NEXT
I DO THAT NEXT
6 years 6 months ago #39188
Replied by Noah on topic FORD FOCUS RS MK2 Engine MALFUNCTION
From what I recall about the Ford fuel rail pressure sensors, it's normal for them to over report by 10 psi.
So if you do decide to backup the pressure displayed by the FRP PID with a reading from a mechanical gauge, don't be surprised to see some discrepancy.
- derekoliveira
6 years 6 months ago #39196
by derekoliveira
Right next to a stall you should check if you have com. with ECM and like Landroverman said cheking 5 volts ref. is a way to confirm if ECM is ON or OFF!
