2015 FORD RANGER 3.2 No low head lamps both side [FIXED]
  • abe1204
  • abe1204's Avatar Topic Author
6 years 6 months ago - 6 years 6 months ago #39367 by abe1204
hi , everyone Good day! I had been encounter Ford ranger A Diesel Enginn 3.2 , The problem are No lights in low head lamps both side So I checked the fuses are good , i do a by pass test from Body Control module I found the two wires running to hlow head lamps ! I get my probe tester and give it 12 volt supply and its lworks , I dont have wiring diagram on this car ,, ,Is there any other option to check this I think the relay is built in Bcm .. Any idea Thanks
Last edit: 6 years 6 months ago by Tyler.
6 years 6 months ago #39369 by Cheryl
We don’t have a 2015 ranger in the USA but have you checked bcm data for headlight output? Or headlamp switch inputs to see if it matches the position of the switch
  • abe1204
6 years 6 months ago #39387 by abe1204
Thank you Cheryl , yes I checked there is switch input .! try to open the Bcm lets see if whats wrong in the Bcm ,
6 years 6 months ago #39403 by Cheryl
Do you have bi directional control to command the headlights on with your scanner??
  • abe1204
6 years 6 months ago #39428 by abe1204
Yes, Cheryl but it does not work when I manipulate in my scanner I check the switch signal is fine .Then I disconnected the wires from Bcm and I give supply Voltage and it works fine
  • abe1204
6 years 6 months ago #39451 by abe1204
Replied by abe1204 on topic UPDATED FORD RANGER NO LOW BEAM IS (FIXED)
No low beams on both side ,now it works fine Its just A BCM RESET ,,
6 years 6 months ago #39453 by Tyler
Replied by Tyler on topic UPDATED FORD RANGER NO LOW BEAM IS (FIXED)
Really? :huh: Well hey, a fix is a fix!
Did this truck have a weak battery or other electrical issues? Just wondering what pissed off the BCM in the first place. When you say BCM Reset, do you mean just unplugging/plugging it back in? Or is there a specific scan tool function?
  • abe1204
6 years 6 months ago #39456 by abe1204
What i saw on this car the battery is new , Hi beam beam is fine only the low beam is not working on that time , so i checked Fuses , Grounds ,in low beam there is no clicking unlike h beam I can hear clicking everytime I turn the hi beam switch , this time im using aurel maxisys elite checked for posiible cause But its not telling me whats fault , So checked the wire color of low beam that goes into Bcm And energize it works fine ,i checked the switch input iits fine, i disconnect all connectors from BCM and i open see if what is wrong on Board but there is no signs of wet water ! so i put it back all and This time Im using LAUNCH i go into BCM read fault and all relay clicking inside Bcm and erase all faults try to turn low beam and It works
