2016 Range Rover sport - diesel fault ; Help needed
- forumoto
- Christ De KING
6 years 6 months ago #39484
by forumoto
Christ De Way Maker
2016 Range Rover sport - diesel fault ; Help needed was created by forumoto
I have this Range Rover sport but diesel and it keep showing codes on the nox monitoring system and SCR.
Please I need help on how to tackle this issue. Attached is a screen picture of the faults codes been read.. I don’t know if it is the sensor being faulty or the particulate filter, please need guides as to what to check, am not that diesel specialist..
Thanks
Thanks
Christ De Way Maker
- tech25
- Thank you received: 27
6 years 6 months ago - 6 years 6 months ago #39516
by tech25
Replied by tech25 on topic 2016 Range Rover sport - diesel fault ; Help needed
There is a bulletin out for some of the codes. I attached a copy, Please follow it closely and report on outcome.
also, please see the video for a explanation of the system, and make sure system is full of fluid.
www.landroverusa.com/ownership/guides-an...lery.html/293-249778
Last edit: 6 years 6 months ago by tech25.
The following user(s) said Thank You: juergen.scholl, forumoto, dani.albom
- forumoto
- Christ De KING
6 years 6 months ago #39708
by forumoto
Christ De Way Maker
Replied by forumoto on topic 2016 Range Rover sport - diesel fault ; Help needed
I have carried out the fault tracing base on the info you have given and tried to performed the special functions in the bulletin you shared with me, I did made some videos which you can download via this web link below, with still permanent dtc’s existing..
So advise me what must be done next...
www.mediafire.com/folder/zdwyy8te1x4ui/
Thank you for your support.. and also to everyone who read my thread.
Christ De Way Maker
- tech25
6 years 6 months ago #39728
by tech25
is the system full of fluid??
did you perform the test drive as indicated in the TSB??
The following user(s) said Thank You: forumoto
- forumoto
- Christ De KING
6 years 6 months ago #39753
by forumoto
Christ De Way Maker
The system is of it level yet nothing works, system was all drained and refilled.
Test drive was performed too
Christ De Way Maker
- tech25
6 years 6 months ago - 6 years 6 months ago #39762
by tech25
ok,... please take a picture of the engine ECU info, and compare to these sw numbers.
L405 GK5212K532PRJ
L494 GK6212K532PRJ
also, I would remove the def injector and inspect it, if you can activate it with the scan tool and verify it is injecting fluid properly in the exhaust,
compare known good tips by the picture,
inspect and make sure there are no exhaust leaks.
clear all faults, then perform a drive cycle to complete the SCR monitor.
1. Idle the engine for 10 minutes.
2. Run the vehicle at speeds between 40 60 mph, for a minimum of 5 minutes avoiding high accelerations.
3. Cruise at 40 mph for around 4 5 minutes, then slowly accelerate to 60 mph, using a steady accelerator pedal input.
4. Pull over safely and conveniently and switch off the engine until the red P symbol is no longer present on the Instrument Cluster.
5. Start the engine and repeat steps 2 and 3 and return to Retailer.
When the 'reset selective catalyst reduction quality' monitor has been successfully completed , the warning message in the Instrument Cluster (IC) will no longer be displayed. The remaining DTCs (P2BAE/P2BAF) can now be cleared from the PCM
L405 GK5212K532PRJ
L494 GK6212K532PRJ
The following user(s) said Thank You: Noah, forumoto
- forumoto
- Christ De KING
6 years 5 months ago #39778
by forumoto
Christ De Way Maker
I will get back to you, after applying this info you have shared with me.
Thanks for your kind input to this thread
Christ De Way Maker
