No crank, no start
- marlontomera
6 years 6 months ago #39563
by marlontomera
No crank, no start was created by marlontomera
My daughter has a 2012 Yukon Denali XL, at first it had a low oil pressure issue. My son-in-law replaced the oil pressure sensor and the vehicle ran for for about half a day then it lost oil pressure again. We decided that the oil pump was the issue, so we replaced it and the pickup tube. We had good oil pressure until the vehicle reached operating temperature, then no pressure and the vehicle told us to shut down the vehicle. So the vehicle set up for about a month, the battery was dead, so we jumped it off and now we have a "No Crank / No Start" issue. We are getting a U0100 code - Lost communications with the ECM/PCM. Where should we start for troubleshooting this issue?
- Cheryl
- Thank you received: 215
6 years 6 months ago #39567
by Cheryl
Replied by Cheryl on topic No crank, no start
Check pins 6 and 14 at the data link connector battery unhooked should see 60 ohms. Also that new oil pressure sensor might be shorted pulling the 5 volt reference. So check for a 5 volt reference and powers and grounds at the pcm
- marlontomera
6 years 6 months ago #39578
by marlontomera
Replied by marlontomera on topic No crank, no start
Thank you Cheryl I will try that. If I remember right, my son-in-law put the old oil sensor back in.
- John Curtis
- Thank you received: 111
6 years 6 months ago #39581
by John Curtis
especially if it's a dorman!
Replied by John Curtis on topic No crank, no start
Cheryl wrote: Check pins 6 and 14 at the data link connector battery unhooked should see 60 ohms. Also that new oil pressure sensor might be shorted pulling the 5 volt reference. So check for a 5 volt reference and powers and grounds at the pcm
Time to create page: 0.265 seconds
