2008 Dodge Ram 3500 no start or crank over
  • V6mod36
  • V6mod36's Avatar Topic Author
6 years 5 months ago #39893 by V6mod36
My 2008 Dodge Ram 3500 Dually 6.7l decided to throw a curve ball at me. It started out it would start up go too idle then shut off. It did this a few times and then it goes too not even cranking over. I have all lights and dash board lights up.
I checked the starter, starter relay, replaced the ignition switch, batteries are perfect, ground wires are good, I'm going crazy with this now been 4 days and still haven't figured it out. PLEASE HELP thank you
6 years 5 months ago #39894 by Hardtopdr2
Replied by Hardtopdr2 on topic 2008 Dodge Ram 3500 no start or crank over
Is this a diesel truck or gas? Do you have any codes or ability to check codes? What's the voltage on the batteries?
  • V6mod36
6 years 5 months ago #39895 by V6mod36
Replied by V6mod36 on topic 2008 Dodge Ram 3500 no start or crank over
This a diesel, Cummins. No codes what so ever off of my scanner
  • V6mod36
6 years 5 months ago #39896 by V6mod36
Maybe the range sensor is causing this, but transmission was rebuilt a year ago.
6 years 5 months ago - 6 years 5 months ago #39900 by Hardtopdr2
Check the other relays for corrosion mainly ones for pcm, power distribution. Then check if you have a 5 v ref. signal or 12 v ref. Signal. Is your pcm on the pass side firewall on the engine side?
ASD relay is one that should be looked at and the wiring diagrams associated with it. ASD is the auto shut down relay. Some diesel engines have the engine shutoff if the coolant temp sensor or the engine coolant fill level sensor detects high temp or low coolant level.
Last edit: 6 years 5 months ago by Hardtopdr2. Reason: More info
  • V6mod36
6 years 5 months ago #39912 by V6mod36
Yes the pcm is on the passenger side. I will check that. Thanks
