[FIXED] 2011 lacrosse cxl dual climate control
  • Cheryl
  • Cheryl's Avatar Topic Author
6 years 5 months ago #39901 by Cheryl
im trying to fix this thing. im in hvac data and looking at ac denial reason it comes up as ambient temperature. the ambient air temp on the radio display shows 16 degrees so i put a 10,000 ohm resistor in place but didnt change anything. so is there a reset or something?? they have a ambient air quality sensor which is under the cowl panel but im not sure what it does.
  • Cheryl
6 years 5 months ago #39902 by Cheryl
Replied by Cheryl on topic 2011 lacrosse cxl dual climate control
its about 55 degrees and it says 16
6 years 5 months ago #39903 by Hardtopdr2
Replied by Hardtopdr2 on topic 2011 lacrosse cxl dual climate control
There should be a ambient temp sensor in front of radiator small two wire connector. Pull the connector and see if the pid changes
  • Cheryl
6 years 5 months ago #39904 by Cheryl
I have a resistor jumped in the 2 terminal connector should be same resistance as around 60 degrees or so. According to the temp vs resistance chart
6 years 5 months ago #39905 by Hardtopdr2
Ok does your scan tool show a pid for the cowl one as well?
  • Cheryl
6 years 5 months ago #39906 by Cheryl
Not that I’m aware of it’s a 3 wire one. Haven’t looked that deep yet in it
6 years 5 months ago - 6 years 5 months ago #39907 by Hardtopdr2
Ok i think it might be worth while to do a resistance check or load test it with a test light or a resistance dial and adjusting it a couple times to see if it changes
There is a manual reset procedure for it as well I think its press mode, defrost, rear defrost at same time for about 10 seconds
Last edit: 6 years 5 months ago by Hardtopdr2. Reason: Edit
  • Cheryl
6 years 5 months ago #39945 by Cheryl
Incorrect service information resistance chart spec ordered new ambient air sensor check resistance with old one way different put it in still no change apparently you have to drive over 35mph for 5 minutes to get it to update now it all works
6 years 5 months ago #39947 by Hardtopdr2
Cool congrats
6 years 5 months ago #39949 by Noah
Replied by Noah on topic 2011 lacrosse cxl dual climate control
Cheryl wrote: Incorrect service information resistance chart spec ordered new ambient air sensor check resistance with old one way different put it in still no change apparently you have to drive over 35mph for 5 minutes to get it to update now it all works
What a joke!
Glad you got it. I've been bit by ABS problems on Buicks that just won't go away until you drive it, but I seriously wouldn't have suspected that out of an ambient temperature problem.
Good find.
  • Cheryl
6 years 5 months ago #39950 by Cheryl
Everyone gets lucky now and again. In get a lot of auction cars you know how it is I’m sure.... auction car means oh crap
6 years 5 months ago #39951 by Noah
Yup, they don't pump them through auction because they're nice cars...
Time to create page: 0.374 seconds
