2012 chevy traverse 3.6. P0300
- gerber
- Thank you received: 4
6 years 5 months ago - 6 years 5 months ago #39924
by gerber
2012 chevy traverse 3.6. P0300 was created by gerber
Hello. I got this 2012 chevy teaverse. With a p0300 code. Check engine light flashing. And when i press the gas pedal Wont pass 1500 rmp and bugdown. And shutt off . And its blowing alot of pressure out of the oil dipstick. And pcv vent hose. To the air box. See the video. Any help will apreciate. All the coils. Was changed. A month ago. And a new. Ac delco sparkplugs. And air filter. And new oil.
Thank you
Thank you
Last edit: 6 years 5 months ago by gerber. Reason: Video
- dustin.combs
6 years 5 months ago #39939
by dustin.combs
Replied by dustin.combs on topic 2012 chevy traverse 3.6. P0300
You may have a fuel related issue that causing random misfires easy stuff first unplug your mass air flow sensor start car up with it unplugged see if your problem goes away.
- Cheryl
- Thank you received: 215
6 years 5 months ago #39946
by Cheryl
Replied by Cheryl on topic 2012 chevy traverse 3.6. P0300
Most likely it’s out of time them 3.6 liter timing chains are junk. Scope cam and crank sensors compare to known good
- allwest57
6 years 5 months ago - 6 years 5 months ago #39970
by allwest57
Replied by allwest57 on topic 2012 chevy traverse 3.6. P0300
If your RPMs will not exceed 1500 ..you might have a clogged cat ..can you monitor the downstream O2 sensor? ..or ..evap purge valve might be stuck closed ..easy to check both of those ..anyway ..my $0.02 ..good luck
Last edit: 6 years 5 months ago by allwest57.
