Setting valve clearance
  • kamiwolf0893
  • kamiwolf0893's Avatar Topic Author
6 years 5 months ago #40105 by kamiwolf0893
Setting valve clearance was created by kamiwolf0893
Hi, I will be performing a valve lash adjustment on my engine soon. The workshop manual specifies a min and max clearance when cold. I'm a little confused what I should be setting this clearance to. I'd assume minimum would be too tight and max would be noisy? If someone could answer this for me i'd appreciate it. Many thanks, Adam
6 years 5 months ago #40106 by tech25
Replied by tech25 on topic Setting valve clearance
set it in the middle of the min and max specs.
  • kamiwolf0893
6 years 5 months ago #40107 by kamiwolf0893
Replied by kamiwolf0893 on topic Setting valve clearance
Thanks for the reply. Do the clearances need to match for every valve?
  • kamiwolf0893
6 years 5 months ago #40108 by kamiwolf0893
I was just asking because I've 2 exhaust valves at 11 thou and the other 6 valves are at 12 thou.
6 years 5 months ago #40109 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Setting valve clearance
As long as it is within specs don't worry be happy
6 years 5 months ago #40114 by John Curtis
Replied by John Curtis on topic Setting valve clearance
I’d always recommend to adjust them on the more tight of the tolerance side. If you set looser on the tolerance side then I’ve always assumed you’ll be doing the job again sooner than you want to. But there’s nothing to really backup that theory.
6 years 5 months ago #40116 by Matt T
Replied by Matt T on topic Setting valve clearance
John Curtis wrote: I’d always recommend to adjust them on the more tight of the tolerance side. If you set looser on the tolerance side then I’ve always assumed you’ll be doing the job again sooner than you want to. But there’s nothing to really backup that theory.
That's going to be engine dependent, and might also vary between intake and exhaust, because some valves wear tighter rather than looser.
6 years 5 months ago - 6 years 5 months ago #40118 by juergen.scholl
Replied by juergen.scholl on topic Setting valve clearance
The reason I like to adjust on the tight side is simply to achieve best breathing/pumping.....
Though you then will have to check periodically the valve lash, especially when the exhaust valves get tighter over time.
Last edit: 6 years 5 months ago by juergen.scholl.
