97 Dodge ram 5.9l magnum crank no start
- Jansa
6 years 5 months ago #40113
by Jansa
97 Dodge ram 5.9l magnum crank no start was created by Jansa
So I posted to try and get some repair help and when I could not the project got put on hold. I have a 1997 dodge ram 1500 5.9L magnum. Replaced the engine with a working one out of a 1996 dodge ram 1500 5.9l magnum. Went to start it and it cranked but would not fire. A cam sensor code came up so I replace it w a new one. Still no start. I also replaced the crank sensor and checked out a few other things. I for some reason my signal wires are getting pulled to ground on the cam crank and tps. When I unplug then they go back to their 5v reference. I ran my code reader while the cam sensor was unplugged and I then got a battery temp. sensor code. Could a bad battery temperature sensor be pulling my signal wire to ground and causing a crank no start on my truck?
- Cheryl
- Thank you received: 215
6 years 5 months ago #40120
by Cheryl
Replied by Cheryl on topic 97 Dodge ram 5.9l magnum crank no start
Do you have communication with the scanner?? If the 5 volt ref is being pulled down usually you’ll get a no bus on the cluster. Also did you inspect the flex plate very close because I’ve seen them be different and cause a crank no start
- Cheryl
6 years 5 months ago #40121
by Cheryl
If you had a scope you could get us a cam crank correlation to rule that out
6 years 5 months ago #40122
I have seen that very same thing on more than one occasion.
Replied by Noah on topic 97 Dodge ram 5.9l magnum crank no start
Cheryl wrote: Also did you inspect the flex plate very close because I’ve seen them be different and cause a crank no start
- Jansa
6 years 5 months ago #40125
by Jansa
Replied by Jansa on topic 97 Dodge ram 5.9l magnum crank no start
I'm not getting a no bus. And unfortunately I do not have a scope nor have I used one before. I do not remember which flex plate I put on though the one from the 96 or the one that was already on the 97. The previous owner threw a rod through the oil pan and locked the engine up which is why we replaced the engine. I will definately look into that. Any other thoughts are more then welcome thanks.
- Hardtopdr2
- Thank you received: 150
6 years 5 months ago #40139
by Hardtopdr2
Replied by Hardtopdr2 on topic 97 Dodge ram 5.9l magnum crank no start
One way to see if to much clearance is take a piece of modeling clay and stick it on the end of crank sensor and seat it back in the opening and remove and measure the thickness of it. That should give you an answer
Time to create page: 0.351 seconds
