finding a short after identifying circut
- johnt
6 years 5 months ago #40463
by johnt
finding a short after identifying circut was created by johnt
I have identified the circut and fuse that is causing a 4 amp draw. I have also traced that wire back to the instrument cluster as it was shown on the mitchell wiring schematic. there were no breaks and i had continuity. I am assuming there are other circuts on the that line however the mitchell diy does not list them. when I pulled the fuse I lost the instrument cluster and the pwr windows. The wiring diagram does not show the windows on the plan. Anyways, if you have any direction I could follow on this i would be appreciative.
thanks, John
thanks, John
6 years 5 months ago #40465
Replied by Chad on topic finding a short after identifying circut
What are you working on? Year, Make, Model, Engine? Which circuit and fuse have you identified as being the problem?
- juergen.scholl
- Active partschanger
- Thank you received: 462
6 years 5 months ago #40471
by juergen.scholl
Replied by juergen.scholl on topic finding a short after identifying circut
The redrawn Mitchell wiring diagrams do not show the complete circuits,,,,,,it's just an excerpt of the "sections of interest". Look for the OE diagrams.
- John Curtis
- Thank you received: 111
6 years 5 months ago - 6 years 5 months ago #40486
by John Curtis
Replied by John Curtis on topic finding a short after identifying circut
OE diagrams are absolutely the way to go.
However, I’d recommend using a test light connected to battery power and on the feed side of the fuse. If you have a path to ground (a short) it would light. you can decide to disconnect whatever is on the circuit or do a visual along the wiring. In my experience, a shorted wire typically draws more amperage so I’d THINK it’s a module however, there’s many variables.
Last edit: 6 years 5 months ago by John Curtis.
