mazda axela or mazda 3 2.0 jy 37 engine
  • cyrus.nk
  • cyrus.nk's Avatar Topic Author
10 years 3 months ago #482 by cyrus.nk
mazda axela or mazda 3 2.0 jy 37 engine was created by cyrus.nk
:woohoo: The car start fine but doesn't accelerate.have checked throttle body and accelerator pendle and are fine.trouble code p2122 -ff.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago - 10 years 3 months ago #485 by Dylan
Replied by Dylan on topic mazda axela or mazda 3 2.0 jy 37 engine
Hey Cyrus. Seems you have an APP sensor DTC... if this is the same as Toyota uses there are 2 hall effect sensors in the pedal.
Just asking but how do you know they're fine?
Check out this link also. Don't know if this applies to your vehicle...
euroesi.mazda.co.jp/esicont/eu_eng/mazda.../id0102c1811700.html
Last edit: 10 years 3 months ago by Dylan. Reason: Forgot link
  • cyrus.nk
10 years 3 months ago #486 by cyrus.nk
Replied by cyrus.nk on topic mazda axela or mazda 3 2.0 jy 37 engine
I know are fine coz wen i test throttle motor moves up and down and i see my scan tool data changes fine.wen i check accelerator pendle pid is working only in one side.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago #487 by Dylan
Don't really understand what you mean. Do you have more than 1 data PID of the APP on your scan tool ?
  • cyrus.nk
10 years 3 months ago #489 by cyrus.nk
Yes.app senor 1 and app sensors 2.only app sensor 1 working fine app sensor 2 never change.hope u understand?
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago #493 by Dylan
Yes. My point exactly. 2 sensors.... Do you have a wiring diagram?
  • cyrus.nk
10 years 3 months ago #496 by cyrus.nk
Oh no!just help if u have one.Thank u
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago #497 by Dylan
I hope Tyler or Noah do. Could you also mention the year? Thx
10 years 3 months ago - 10 years 3 months ago #498 by Noah
Replied by Noah on topic mazda axela or mazda 3 2.0 jy 37 engine
Seems like the pedal assembly is faulty, that's why they have redundant potentiometers on them, so if one craps out, you're not totally dead on the road.
I'd start with a simple visual of the connector and related harness in the under dash area, maybe even a wiggle test in the area while watching scan data. If you can provide the year, I'll see if I can find a diagram for the American counterpart to this car.
Should be a fairly straight forward diagnosis.
there's going to be 2 wires with their own 5v ref source each, at least one ground, MAYBE 2. And 2 signal wires. One will sweep from 5 to 0v, the other from 0 to 5v. as you move the pedal (probably more likely see 4.75v to 0.5v, but you get the idea).
You're a smart guy, with a backprobe, a multimeter, a flashlight and some patience, I bet you can trouble shoot this without a diagram.
Last edit: 10 years 3 months ago by Noah. Reason: spelling
  • cyrus.nk
10 years 3 months ago #504 by cyrus.nk
Mazda 3 2006
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago #517 by Dylan
Ok thx for the year. Have you tried to do some measurements on the APP like Noah suggested?
10 years 3 months ago #526 by Tyler
Replied by Tyler on topic mazda axela or mazda 3 2.0 jy 37 engine
Dylan wrote: I hope Tyler or Noah do. Could you also mention the year? Thx
Why'd you mention me? It's not like I post wiring diagrams ALL the time! lol
Actually, I found one, but it honestly kinda sucks:
We can't even see where the yellow wire goes! I *think* it's supposed to be a sensor ground, but don't quote me there.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago #553 by Dylan
:lol: When I see 'wiring diagrams' I immediately think of Tyler! Haha
Well at least you found something....
  • cyrus.nk
10 years 3 months ago #558 by cyrus.nk
Have not tried but i will be working on that car tommoror oooh.i will post a fix here men!wiring diagram?kindly needed if possible.have discovered mazda e app sensor dnt work exactly like toyota.I mean 2 wires for 5 volts for app 1 and app 2.it is one wire for 5 volts and its signal wire and the other wire has 10 volt for app 2 when unpluged.plugged in 1 volt at idle wen pressing the gas 1 to 7 kindly check it u will see on white wire ooooooh
10 years 3 months ago #585 by Noah
It's not like his avatar is a wiring diagram or anything :P
10 years 3 months ago - 10 years 3 months ago #588 by Noah
Attachment not found
Looks like from left to right:
Ground
Sensor Ground
5v ref
Position signal ( 1 or 2)
Position signal (1 or 2)
Battery +
So not quite what I was thinking to begin with. Hope this helps you.
10 years 3 months ago #589 by Tyler
I actually liked what you were thinking the first time, as that's what I usually expect with an APP sensor. Mazda just had to be different, I guess?
And how DARE you judge me based on my avatar! lol
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 3 months ago #610 by Dylan
Don't you love this Asian crap? :lol:
  • cyrus.nk
10 years 3 months ago #612 by cyrus.nk
Oop!!another problem oooo.the car dnt start no injection/ignation pulse and am getting 3.45 on control wire on injectors and 5 volts on ignation coil controll wire wen unplugged,plugged 0 volt.DANNER tells if i have voltage on control wire possibly i have bad computer ground.check the computer ground and it's ok.
10 years 3 months ago #629 by matt.white
Replied by matt.white on topic mazda axela or mazda 3 2.0 jy 37 engine
And this happened without anything else being touched? Your post is a little vague but I'd expect to see battery voltage at the injectors, even with a dead ecu. You don't say if that's cranking or constant? You have a scope or just multimeter?
Time to create page: 0.377 seconds
