[FIXED] 94 Sonoma 4.3W no power
- kvnber4
replaced tank and pump fp good
AC cap ,rotor,wires
150LB comp. all cylinders.
EGR Ok.
No Cat,new muffler
New O2 sensor
ECT good
spark jumps approx 1/2 inch but looked a bit orange. Replaced coil, still looks the same. Grounded one cylinder at a time with test light. All cylinders contribute equally at idle.spark still appears a bit orange. Ig mod.??? ECM??? HELP !!!!!
- cheryl hartkorn
- Thank you received: 130
The muffler blowing apart really says spark timing to me. Do you have access to a timing light? I'd be interested to know if the spark advances correctly while the engine is power braked (you'll need an assistant for this). Seeing the spark timing jumping around, or seeing the light stop flashing, would be a great indication of a spark control problem.
These distributors are known for cracked magnets AND tone wheels slipping off the distributor shaft, both of which can cause symptoms like this. If you don't have access to a timing light, you could try using an in-line spark tester on the coil wire to watch the spark as you're accelerating. I use this style of tester regularly, works perfectly:
Seeing the spark 'break up' or lose strength would be a big red flag for the ignition system.
Cheryl asked about fuel delivery, and I'm wondering the same. I see that this got a fuel pump and tank, but I'd still like to know the actual fuel pressure reading at idle and under load. Memory says it needs to be at least 55-60 PSI running.
- kvnber4
- cheryl hartkorn
kvnber4 wrote: Fuel pressure is right on the money. I used that exact spark tool and the spark is not blue. It will jump a good 1/2" but it is a bit orange. When I rev it up the spark remains the same. It sure feels like an ignition issue. I really appreciate the help from all. I will keep at it. Thanks!!!
So just to be clear, when you try to duplicate the low power, the spark stays strong?
The orange color doesn't bother me so much, as it's still jumping a 1/2" gap. I guess that could be a sign of a weak coil, but I'd think that'd show up during the low power with the spark tester.
- cheryl hartkorn
- kvnber4
- kvnber4
- kvnber4
- Dylan
- Belgium, Europe
- Thank you received: 327
- kvnber4
- Dylan
- Belgium, Europe
- kvnber4
So, I believe you about the Y-pipe being restricted, but I'm trying to connect that to the muffler blowing out. :blink: Unrelated issue?
- kvnber4
kvnber4 wrote: Yes , that has crossed my mind. Not sure what happened there. The original O2 sensor was distorted/slightly melted . I assumed my son did that when he heated it to take it out . But he tells me he only heated it a little bit to get it out. If the O2 failed/ got too hot , maybe it dumped too much fuel ?????
Could be! Well, I'm sorry our advise was off base, but I'm still happy it's running right again.
