bmw 2006 525i no crank
  • A93320336@gmail.com
  • A93320336@gmail.com's Avatar Topic Author
6 years 4 months ago #40985 by A93320336@gmail.com
bmw 2006 525i no crank was created by A93320336@gmail.com
team good day
bmw 2006 525i no crank no ignation
when put key in ignation is tern but do nothing like no battry
my feriend told me due to scierty it will not open the ACC if key missing the transponder i scan for code no code
i check all fuse and i chack the coil ring by vvdi key tool and it try to read the key
6 years 4 months ago #41002 by szgonik
Replied by szgonik on topic bmw 2006 525i no crank
I suppose you checked battery voltage and that starter has good power and ground?
I don't have personal experience with these cars but I know the battery ground cable is not just plain old cable. There's some electronics in the cable with it's own microprocessor I think that monitors battery parameters. And it's known to go bad often causing all kinds of electronics problems possibly even no start. So maybe it's something to look at.
Are you using BMW specific diagnostic tool to read the codes?
