[FIXED] 02 Acura TL type S rough idle, -15% ft at idle, random miss
  • Linnadawg
  • Linnadawg's Avatar Topic Author
6 years 4 months ago #41058 by Linnadawg
Car is idling rough and has a misfire pop up for cylinders 4, 5 or 6 occasionally and will idle very rough. Stft is around -10% while Ltft is around -5%. Just did valve cover gaskets, spark plugs and all intake gaskets and issue remains. Tried a cylinder drop test and all coils made rpm change. Map reading is around .85v which is a little low.
Car has 230k miles, leakdown test performed and all cylinders holding around 18-20% leakage.
6 years 4 months ago #41068 by Cheryl
Does the oxygen sensors react to rich and lean conditions?? Coolant temp readings??
6 years 4 months ago #41069 by Cheryl
Also this thing have an egr valve? If so it sounds like a stuck open egr valve rough idle?
  • Linnadawg
6 years 4 months ago #41070 by Linnadawg
Cleaned egr valve it wasn’t that bad. Cleaned passages in manifold as well. Coolant temp was around 200f and in closed loop. Oxygen sensors were working but seems like cat is going out.
A valve adjustment fixed it. Most of the valves were in spec but I noticed on cylinder six intake valves were way tighter than spec. Map voltage is above .9v at idle now as well.
6 years 4 months ago #41072 by Hardtopdr2
If you have any leakage you have a problem... valves not sealing or engine not at tdc compression when doing leakage test. If it is at tdc compression then which end do you hear airflow (through throttle body or exhaust pipe)?
6 years 4 months ago #41073 by Hardtopdr2
Lol helps to read the entire topic before posting lol glad you figured it out
