2013 chevy sonic 1.8 liter . no crank ,no start condition
- Peterpaul
- Thank you received: 2
car was towed in two weeks ago. We are not getting any voltage to the S wire (yellow wire) on the starter with the key in the crank position. if you jump the S wire across the battery wire the car will start.
to further complicate things when you hook a scanner up, it comes up with 21 codes. We cannot clear the codes. Now for the fun part:
the ignition switch and the crank/start relay have been replaced with no help.
If you remove the three wire connector from the cam angle position sensor the car starts and runs fine. All the accessories work as well including the RPM tach . I tried to test the three wires that I saw in your video, but I didn't understand what the tests where telling me..
As you can tell my electrical experience is very weak. I have ended a thirty year career and i'm starting back in the automotive field . I have watched several of your videos and they have been helpful but I still need some scanner danner guidance to troubleshoot the system before we keep on replacing parts and I learn nothing.
I would appreciate what ever step by step troubleshooting efforts you have time for. I can be reached by phone as well . 620-506-1727
thanks again for your time.
- Cheryl
- Thank you received: 215
- Peterpaul
the codes are as follows:
DTC DESCRIPTION
p2227, P2228,P2229,P2230.
SHORT TO GROUND P0641, P2227,P2228
OPEN HIGH RESISTANCE
P2228,P2227,P2229
SHORT TO VOLTAGE
P0641.P2229.P2227,P2229
SIGNAL PERFORMANCE
P2227
thanks for the response AND YOUR HELP .
- Peterpaul
Check the voltages at the unplugged connector with the key-on/engine-off.
thanks again
What are the wire colors at the sensor you're unplugging? A photo would be awesome, if possible. We can provide pin voltage information once we know exactly which sensor and wires we're talking about.
The P22XX codes all have to do with the BARO sensor... Is that sensor plugged in? Or is that the one you've been disconnecting?
- Peterpaul
I also need to check the part number for the sensor that we replaced. i'm not sure if we new that there ARE two Cam position sensors.
Anyhow,
the original exhaust cam position sensor was removed and re installed. With the wire unplugged the car starts.
thanks again for all your help.
- Peterpaul
Peterpaul wrote: it is the exhaust sensor. I will take a picture of the wires in another hour when i am back at work.
Gotcha, thanks!
Pin #1 - Grey/yellow, 5V KOEO, plugged in or disconnected
Pin #2 - Grey/black, 0V/ground at all times
Pin #3 - Violet/black, sensor signal. OE diagram suggests this is a pull down sensor. So, you can probably expect 5V KOEO with the sensor unplugged, and 5V or 0V with the sensor connected, depending on the position of the exhaust camshaft reluctor.
The pin numbers are looking at the female end of the connector, right to left. I only mention that because it's not impossible that someone has rewired this connector backwards before you got to it.
- Peterpaul
thanks for the voltage readings. I will let you know Monday what the values are. I have also attached the four scan codes that came up as well.
cheers and thanks again for your help
- Peterpaul
Good morning . I am on my way to work to perform the voltage readings and report them back to you. Is it possible for me to call you to see where to go from here after you review the readings or will it be quicker to have you reply by email?
let me know and again thanks for all your help on this.
- Peterpaul
I hope your Monday is going well. How do I check my private messages?
Here is the voltage results for the three wires that feed the exhaust cam position sensor:
1. pin one grey/ yellow with the connector unplugged and the key on ,with the car not running i'm only getting 1 volt. it should be 5 volts.
2. Pin two grey /black 0 volts ground at all times. Correct. I even verified the ground by hooking my test light to the positive battery terminal and the test light lit.
3. pin three violet/black sensor signal. pull down sensor. key on with the car not running. sensor unplugged 12 volts .
I will go back and check Pins one and three again with the car running..
remember , this car runs fine with the exhaust cam position sensor unplugged. the car was driven today on the road for an hour with no problem.
Thanks again for your time and patience ,
your awesome ,
- Peterpaul
thanks again > I found my private messages. I will be in touch.
thanks
The SI for P0641 spells out the suspects. A/C pressure sensor, intake CMP sensor, exhaust CMP sensor, fuel tank pressure sensor and multifunction intake air sensor (MAF sensor). Those are all the sensors that run on the #1 5V ref circuit.
Focus on those.
- Peterpaul
Thank you for not letting me be a parts changer:D
Did you get anywhere on the stubborn Sonic?
