Toyota tundra lean codes on both banks
  • Christian77
  • Christian77's Avatar Topic Author
6 years 3 months ago #41210 by Christian77
Toyota tundra lean codes on both banks was created by Christian77
Wondering if I can get some info I have this toyota tundra 06 4.7 has lean codes on both banks p0171 p0174 has a new mass airflow and I replaced the I take gasket as there was defenatly a couple misfires when spraying water around intake but still the same fuel trims 28 percent on long terms and about 10 -8 short terms fuel pressure is 44 any suggestions on what to do for some reason the when I spray a small amount of carb cleaner into oil fill cap and fuel trims go negative emidiatly
6 years 3 months ago #41218 by tech25
Replied by tech25 on topic Toyota tundra lean codes on both banks
sounds like you have more vacuum leaks, I would hook up a smoke machine somehow to the air intake manifold, and block off the fresh air intake pipe going to the filter as best you can and look for leaks.
6 years 3 months ago #41896 by John Clark
Replied by John Clark on topic Toyota tundra lean codes on both banks
To verify it's a vacuum leak you can rev the engine to 3000 rpm and see if the fuel trims improve. If they do, it's definitely a vacuum leak. Then smoke test the intake as suggested above.
