Two wire CKP sensor question
  • Darren
  • Darren's Avatar Topic Author
6 years 3 months ago #41492 by Darren
Replied by Darren on topic Two wire CKP sensor question
Just an update on this code 14 thrown on a 1996 Hilux Surf with a 1kz-te engine. I retarded the pump timing ever so slightly and bingo! No more engine check light shouting code 14! Why the timing was out I have no idea because no one has adjusted the timing on this vehicle. It does say the the factory manual though that code 14 is related to the TCV (Timing control valve) being more than 7 degrees off TDC. I have saved the waveforms on the Snapon and I'll take a look later to see if there is some definitive way of determining timing relationships between the NE, TDC & TCV signals from the before and after images.
Thank you all for your contribution to this thread. And the answer to my question on the thread title, i found the best results on the waveforms using ECU ground at the ECU and taking the sensor readings from the ECU rather than the sensor itself.
The following user(s) said Thank You: guafa
