08 Kia Sorento
  • Ccglenn
  • Ccglenn's Avatar Topic Author
6 years 3 months ago #41864 by Ccglenn
08 Kia Sorento was created by Ccglenn
No power to a/c compressor, fuse good,relay is hot at terminal 87 when the control is set to a/c on, I can’t make heads or tails of the diagram yet
6 years 3 months ago #41867 by Noah
Replied by Noah on topic 08 Kia Sorento
Could you please provide engine size, fwd/AWD, automatic/manual air conditioning
6 years 3 months ago #41883 by Hardtopdr2
Replied by Hardtopdr2 on topic 08 Kia Sorento
Swap relay with another in the box and see if it comes on then if it does a/c relay is bad. Also check data pids for ac in bcm or hvac module see if it is sending signal or if it says ac dissabled by pressure switch.
  • Ccglenn
6 years 3 months ago #41886 by Ccglenn
Replied by Ccglenn on topic Re:08 Kia Sorento
08 Kia Sorento 3.3 l engine selectable 4 wheel drive , Kia factory called back today the mechanic found a broken wire to the compressor, not sure why the clutch burned up I do have another new clutch so since my system is full of Freon and oil I don’t want to let it out I’m so far in money wise .
  • Ccglenn
6 years 3 months ago #41887 by Ccglenn
True the relay swap was ok dealer scanned all hvac controls my scanner is not good enough
  • Ccglenn
6 years 3 months ago #42004 by Ccglenn
I found that the coil ground had come loose I guess that helped to burn it up, all is well now finally
