no crank no start for f150 2014
  • A93320336@gmail.com
  • A93320336@gmail.com's Avatar Topic Author
6 years 2 months ago #42082 by A93320336@gmail.com
no crank no start for f150 2014 was created by A93320336@gmail.com
dear no start no crank ford f150 2014 6.2l
i jemp the starter relay it start with key in cranking postion
no signal from pcm from the pin 7 yel it should power the starter relay by 12V due to pin 37 wht/gren is ground
i check pin 16 blu/wht at pcm while i crank it get 12v
i check live data at pcm it show it is at park and while i crank it change to start and no fult code on it
can i call it is bad pcm
thanks
