Re:1994 infiniti g20 2.0L crank no start
6 years 2 months ago #42094 by wedo
1994 infiniti g20 2.0 crank no start
spark ok, injector pulse ok, air entering to the engine ok, compression ok
fuel pressure checked before the injectors is 40psi.
what I don't see is fuel in the return hose coming out the injectors rail.
and cranking security light blinks....... what it could be......
6 years 2 months ago #42119 by Tutti57
Replied by Tutti57 on topic Re:1994 infiniti g20 2.0L crank no start
I suspect security mode may have disabled the injectors. You could spray a fuel source into the intake to see if it tries to start to build on that theory. An injector balance test would certainly confirm no injector pulse. The next question would be why? I am not experienced with security issues, if that's what this is, but I'm sure others are.
Nissan Technician
6 years 2 months ago #42122 by wedo
Replied by wedo on topic Re:1994 infiniti g20 2.0L crank no start
I allready did spray a fuel sourse and it doesn't even try to start
I have spark compression injector pulse fuel pressure
6 years 2 months ago #42124 by Tutti57
What did you do to confirm injector pulse? A test light would work for that, or pulling a plug to find a stinking soaked plug after cranking with no start.
Nissan Technician
6 years 2 months ago #42146 by Tutti57
Ah, yes. That's probably right.
Nissan Technician
6 years 2 months ago #42173 by wedo
I used a test light to check the injector pulse,
I think it could be a clogged CAT. maybe the engine it's not breathing enough
(((maybe I'm wrong)))
6 years 2 months ago #42174 by wedo
yeah, but it cranks and it has spark, injector pulse, compression, maybe what it needs it's air on the outlet (exhaust)
6 years 2 months ago #42193 by wedo
yeah you're right, maybe fire at the wrong time
I removed the 02 sensor and a park plug to make sure it's breathing
Time to create page: 0.346 seconds
