MB W210 overfueling bad
  • Wyeth
  • Wyeth's Avatar Topic Author
6 years 2 months ago #42371 by Wyeth
MB W210 overfueling bad was created by Wyeth
Godo day all
Only my second post here, sorry about that, buts its out of desperation. So here goes
Vehicle in question is a 1998 model W210 E280 Mercedes Benz running the M112 engine. Car was and still is extremely heavy on fuel, with grey smoke coming out the exhaust and a lip and mouth burning smell that isnt scared of the devil himself. Car diagnosed with a P0100 code using a iCarsoft MB V1.0 scanner connected to the 38 pin connector under the bonnet, as this model never came with the 16 pin obd plug under that dash. I have since purchased a brand new Bosch maf and fitted that, replaced plugs, plug wires and coil packs, changed all filters and oil. I have since noticed that fuel is mixing with the engine oil, which a cause for concern for me, as it could do some serious damage.
Im more than willing to check, test and do whatever I need to, I just need some guidance as to where to start this. I would greatly, and I mean greatly appreciate some sought of advice. I havent started learning live data yet, so Im hoping someone can spot something out of the ordinary with the car. Here are three frames of the vehicle taken with the above mentioned scanner
BENZ_EN_TEST_00007>E(210)>As of 03-1997>210.063 - E280>Manual>ECM - Engine Control Module(HFM SFI, ME2 SFI)>Read Fault Code:
Total Number : 1
P0100 1/1
State: Historic
Hot film mass air flow sensor(B41)
BENZ_EN_TEST_00007>E(210)>As of 03-1997>210.063 - E280>Manual>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Test engine 1:
Total Frames: 14 , Supported Items: 13
Frame 1/14:
B11/4(Coolant temperature sensor)
49°C
49°C
Intake air temperature
8°C
Engine speed
726rpm
Engine speed
730rpm
Engine load
21.08%
Air mass
1075.50kg/h
Throttle valve angle
0.32°
Ignition angle
-1277° CA
Injection time
9.85ms
HFM-SFI voltage
1.41V
Engine oil temperature
-40°C
Engine oil level
20.96mm
Frame 2/14:
49°C
49°C
8°C
Engine speed
734rpm
Engine speed
734rpm
Engine load
21.08%
Air mass
1075.50kg/h
0.32°
Ignition angle
-1276.90° CA
Injection time
10.09ms
HFM-SFI voltage
1.40V
-40°C
Engine oil level
20.96mm
Frame 3/14:
49°C
49°C
8°C
Engine speed
728rpm
Engine speed
735rpm
Engine load
21.08%
Air mass
1075.50kg/h
0.32°
Ignition angle
-1276.90° CA
Injection time
10.32ms
HFM-SFI voltage
1.40V
-40°C
Engine oil level
21.17mm
6 years 2 months ago #42375 by Hardtopdr2
Replied by Hardtopdr2 on topic MB W210 overfueling bad
Looks like maf is over reporting from the conversion to grams per sec i got 298.75 g/s.
  • Wyeth
6 years 2 months ago #42376 by Wyeth
Replied by Wyeth on topic MB W210 overfueling bad
Hi. Thanx for the reply.
I actually spoke to a guy today, and he asked me if I knew what that air flow value was. I told him its a just over a 1000 odd kg per thingy. He said it might be the scan tool not doing a proper conversion on that.
Regardless, its a brand new Bosch maf, and im positive, if I put the old maf back it would probably be the same. I was wondering if it might have something to do with the O2 sensors. If I have fuel exiting the exhaust, I can just imagine what the O2 sensors look like.
Os there anything else I can look at that could cause such a deviation? Or anything else I can check pls?
6 years 2 months ago #42378 by Hardtopdr2
If you look at fuel trim data with o2/ af sensor reading and post those we can see if they will need looked at. If sensor is stuck comanding more fuel then that could cause your condition as well. Do you have a scanner that can show live data?
6 years 2 months ago #42379 by Matt T
Replied by Matt T on topic MB W210 overfueling bad
Oil temperature is way too low, looks like an either open or shorted default value. If the PCM uses that as part of its open loop fueling strategy that could be making the the motor run rich.
  • Wyeth
6 years 2 months ago #42380 by Wyeth
Hardtopdr2 wrote: If you look at fuel trim data with o2/ af sensor reading and post those we can see if they will need looked at. If sensor is stuck comanding more fuel then that could cause your condition as well. Do you have a scanner that can show live data?
Yes, I should be able to do live data with the iCarsoft. ill do it tommorow, its late where I am, and cold
And yes, I noticed that the oil temp is super low. Couldnt figure that on, but when I spoke to another chap he said that would not effect fueling. One other thing, coolant temp in this printout, was lower than the temp reported by the gauge in the vehicle.
6 years 2 months ago #42381 by Matt T
Hardtopdr2 wrote: Looks like maf is over reporting from the conversion to grams per sec i got 298.75 g/s.
Just for S & G I plugged that g/s into a VE calculator. Had to increase RPM to 10,500 to get the VE down to 100% :silly:
What it may be is the scan tool incorrectly displaying 3 g/s which would be about right for a 2.8L at idle. Decimal point in the wrong place deal.
6 years 2 months ago #42382 by guafa
Replied by guafa on topic MB W210 overfueling bad
Hi everyone,
Assuming data is true, you have also an engine oil temp. sensor reporting -40 celcius (which increases pulse width but not that bad (Seems is unplugged)). I don´t know exactly how this sensor is affecting, but the fact you have injector firing at about 10ms is definitively a rich condition (They should be something about 5ms at that coolant temp.) This is also telling us PCM is responding to what she is seeing.
Is the air temp. reporting right? I mean, can you verifiy that temp?
I don´t have experience with this engine. I suposse it´s a 2.8 liter, which should be reporting about 3g/s at idle.
My first shot would be check power and ground at PCM and try to check whether or not scanner is telling me the truth. If so, then i would check for MAF sensor power and ground. Then unplug it and see how PCM reacts.
  • Wyeth
6 years 2 months ago #42383 by Wyeth
would assume that maf is reporting correctly, its brand new. As for air temp, I actually took 14readings, and all of them show the exact same intake air temp. No change on this or oil temp at all. Here are the remaining readings I took a few days ago.
Frame 4/14:
49°C
49°C
7°C
Engine speed
727rpm
Engine speed
730rpm
Engine load
21.08%
Air mass
1075.50kg/h
0.32°
Ignition angle
-1276.90° CA
Injection time
10.53ms
HFM-SFI voltage
1.40V
-40°C
Engine oil level
21.17mm
Frame 5/14:
49°C
49°C
7°C
Engine speed
730rpm
Engine speed
726rpm
Engine load
21.08%
Air mass
1075.50kg/h
0.32°
Ignition angle
-1277° CA
Injection time
9.93ms
HFM-SFI voltage
1.41V
-40°C
Engine oil level
21.17mm
Frame 6/14:
49°C
50°C
8°C
Engine speed
737rpm
Engine speed
730rpm
Engine load
21.08%
Air mass
1075.50kg/h
0.32°
Ignition angle
-1276.70° CA
Injection time
10.26ms
HFM-SFI voltage
1.40V
-40°C
Engine oil level
21.17mm
Frame 7/14:
50°C
50°C
8°C
Engine speed
741rpm
Engine speed
732rpm
Engine load
21.08%
Air mass
1075.50kg/h
0.32°
Ignition angle
-1277° CA
Injection time
10.78ms
HFM-SFI voltage
1.40V
-40°C
Engine oil level
21.37mm
Frame 8/14:
50°C
50°C
8°C
Engine speed
742rpm
Engine speed
735rpm
Engine load
20.58%
Air mass
1049.90kg/h
0.32°
Ignition angle
-1277.20° CA
Injection time
10.79ms
HFM-SFI voltage
1.40V
-40°C
Engine oil level
21.17mm
Frame 9/14:
50°C
50°C
8°C
Engine speed
738rpm
Engine speed
744rpm
Engine load
20.58%
Air mass
1049.90kg/h
0.32°
Ignition angle
-1275.10° CA
Injection time
15.47ms
HFM-SFI voltage
1.85V
-40°C
Engine oil level
21.37mm
Frame 10/14:
50°C
50°C
7°C
Engine speed
1311rpm
Engine speed
1303rpm
Engine load
31.62%
Air mass
1613.70kg/h
3.54°
Ignition angle
-1275.10° CA
Injection time
15.57ms
HFM-SFI voltage
1.85V
-40°C
Engine oil level
21.37mm
Frame 11/14:
49°C
49°C
6°C
Engine speed
1304rpm
Engine speed
1303rpm
Engine load
31.62%
Air mass
1613.70kg/h
3.54°
Ignition angle
-1275.10° CA
Injection time
15.58ms
HFM-SFI voltage
1.87V
-40°C
Engine oil level
21.37mm
Frame 12/14:
49°C
48°C
6°C
Engine speed
1312rpm
Engine speed
1304rpm
Engine load
31.62%
Air mass
1613.70kg/h
3.54°
Ignition angle
-1275.10° CA
Injection time
15.67ms
HFM-SFI voltage
1.84V
-40°C
Engine oil level
21.37mm
Frame 13/14:
48°C
48°C
6°C
Engine speed
1300rpm
Engine speed
1301rpm
Engine load
31.62%
Air mass
1613.70kg/h
3.54°
Ignition angle
-1275.20° CA
Injection time
15.64ms
HFM-SFI voltage
1.86V
-40°C
Engine oil level
21.57mm
Frame 14/14:
48°C
48°C
6°C
Engine speed
1301rpm
Engine speed
1310rpm
Engine load
31.62%
Air mass
1613.70kg/h
3.54°
Ignition angle
-1275.20° CA
Injection time
15.74ms
HFM-SFI voltage
1.86V
-40°C
Engine oil level
21.57mm
BENZ_EN_TEST_00006>E(210)>As of 03-1997>210.263 - E280>Manual>ECM - Engine Control Module(HFM SFI, ME2 SFI)>View Data>Test engine 1:
Total Frame: 1 , Supported Items: 12
Frame 1/1:
46°C
6°C
Engine speed
727rpm
Engine load
21.08%
Air mass
1075.50kg/h
Injection time
10.44ms
Battery voltage
11.45V
HFM-SFI voltage
1.40V
Fuel tank level
Too Low
Idle speed recognition
ON
-40°C
Engine oil level
20.15mm
6 years 2 months ago #42384 by guafa
Have you noticed coolant temperature sensor (ECT) is almost the same in all the captures?
Engine coolant and Maf readings are the main signals PCM takes into acount (at idle) to comand the amount of fuel. Anyway you have to many sensors reporting wrong readings. That makes me think if scanner is telling the truth (i doubt it).
If you have a DVM you can verify voltage at ECT sensor (cold engine, something about 3.5 - 4.5vdc (Neg test lead to negative battery lead). Hot engine something about 0.5 - 1.0vdc).
You can also check Maf voltage but here we need information about if signal control output is voltage or frequency.
Again, If scanner is right. Check for PCM (and sensors) power and ground.
6 years 2 months ago #42393 by Ben
Replied by Ben on topic Re:MB W210 overfueling bad
Hate to say it but that data appears unreliable and unreliable data is the worst thing to have in diagnostics so get rid of that scan tool and save yourself the headache of chasing wrong data...
Sent from my Pixel 3a XL using Tapatalk
  • Wyeth
6 years 2 months ago #42394 by Wyeth
Replied by Wyeth on topic Re:MB W210 overfueling bad
Only working scanner I have at the moment. I had a friend that came over with his MB Star a while back, and he couldnt get into any of the modules back then. Initially I thought that his unit was faulty, but then he came with a launch x431, same thing. Im surprixed thsi little scanner can get into the modules.
May I just ask, what is the pcm? I would like to go and check these items later today with my dvm
  • Wyeth
6 years 2 months ago #42395 by Wyeth
Maybe I should have said that right at the beggining, apologies if this might be related
  • Wyeth
6 years 2 months ago #42398 by Wyeth
I did get a oil level low notification once on the dash display, never thought anything of it becasue i know its at the correct level
  • Wyeth
6 years 2 months ago #42399 by Wyeth
Will check everything mentioned here a bit later today. Whats the pcm mentioned above?
  • Wyeth
6 years 2 months ago #42401 by Wyeth
Thank you sir. Much appreciated
if there is anything else i can check, please lt me know
6 years 2 months ago #42406 by Ben
Replied by Ben on topic Re:Re:MB W210 overfueling bad
I'm leaning towards this vehicle doesn't have an oil temp sensor and the unreliable scanner has a pid for it so it fills it with a value(like the b2s2 full trims being 99.9%on many low level scanners) this data is not reliable enough to use , also the oil level sensor does not measure oil pressure so that light is unrelated to the oil pump
6 years 2 months ago #42409 by guafa
Hi everyone,
Wyeth. You must check power and ground at pcm and sensors, not by ohm readings but voltage drop readings (which stresses power and gruond).
Take a look at related scannerdanner videos.
The following user(s) said Thank You: Wyeth
  • Wyeth
6 years 2 months ago #42411 by Wyeth
Had a bit of time now, and stuck a bi directional led across the injector leads while disconnected from the injectors with the ignition in position 2 and engine not running, and the led lights up. Not very bright, but it lights up. is that normal?
Checked resistance on injector plugs, on a few I get not resistance, and on other I get about 1k
  • Wyeth
6 years 2 months ago #42415 by Wyeth
Found this on the site, describes exactly what Im having
www.scannerdanner.com/forum/post-your-re...-signal.html?start=0
Time to create page: 0.395 seconds
