Re:driver side drive tires spin when taking off from a stop
- bcnyaa
6 years 2 months ago #42487
by bcnyaa
driver side drive tires spin when taking off from a stop was created by bcnyaa
I have a 2004 Monaco Dynasty with a 400 cummins and allison 3000 6 speed. Today when i took off from a stop the driver side drive tires would spin if i gave it to much throttle. This is on dry level pavement. The coach has a tag axle also if that makes any difference.
- Hardtopdr2
- Thank you received: 150
6 years 2 months ago #42489
by Hardtopdr2
Replied by Hardtopdr2 on topic driver side drive tires spin when taking off from a stop
Could be a air suspension issue with drive axle or you did not let air brake compresssor build pressure past 60 psi to release all air brakes.
- bcnyaa
6 years 2 months ago #42494
by bcnyaa
Replied by bcnyaa on topic driver side drive tires spin when taking off from a stop
thanks for the reply. i was kinda thinking the same thing about air supply to the axle. the system was fully charged at 125 lbs however.
- Hardtopdr2
6 years 2 months ago - 6 years 2 months ago #42499
by Hardtopdr2
Well when was the last time you had the brakes, wheel bearings and wheel seals looked at. The brake slack adjusters might need adjusting or a s cam is stuck on the pass side of drive axle. Is the back side of brakes (axle side) wet aka not completely dry. If so this can cause the brake pad to stick to the drum on the one side as well. Let me know what you find
Oh do you have individual push switches for air brakes and air suspension?
Last edit: 6 years 2 months ago by Hardtopdr2.
- Ben
- Thank you received: 215
6 years 2 months ago #42500
by Ben
Replied by Ben on topic Re:driver side drive tires spin when taking off from a stop
Check the level valves make sure your ride height actuators are not broken and properly adjusted. I'm leaning towards the tag axle is carrying all the weight.
Sent from my Pixel 3a XL using Tapatalk
- hoosierrick
6 years 2 months ago #42501
by hoosierrick
Replied by hoosierrick on topic driver side drive tires spin when taking off from a stop
Did you check for a warm brake drum?
- bcnyaa
6 years 2 months ago #42521
by bcnyaa
thanks hardtop2dr its at the shop now getting these things checked out. and yes it does have seperate switches.
- bcnyaa
6 years 2 months ago #42522
by bcnyaa
Replied by bcnyaa on topic Re:driver side drive tires spin when taking off from a stop
thanks ben. that is getting checked on today.
