high fuel trims in the negative %
- jesg45
- Cheryl
- Thank you received: 215
- Hardtopdr2
- Thank you received: 150
Did you also ohm test the injectors and get a waveform for each injector?
- jesg45
- Hardtopdr2
With the iac an easy way to tell is to look at scan data for commanded rpm and actual. If there is a difference in rpm of 100 or more that will need replaced.
With the maf sensor remove it from car and clean it with maf sensor cleaner and a q tip or acid brush (tin wrapped bristle brush ) spray cleaner inside where wires are and on qtip/brush and clean off the wires very gently. Spray the wires inside maf again and let dry. Reinstall and start car does it idle better and fuel trims get better (closer to zero)?
Let me know
- jesg45
- jesg45
- Hardtopdr2
You must be hitting rev limiter which will do that in park or neutral.
Does the scanner you have do live data ie can graph the upstream and down stream o2 sensors.
If so i want you to start car and let it get into closed loop. Then get scanner set to graph o2 activity ie the millivolts reading. Now with car idling unplug a vacuum line and watch scanner to see if o2s react quickly short term will react the fastest then downstream should react shortly after that. Voltages should fluctuate for upstream and down stream till you disconnect vac line. Do both peg out high .9 millivolts? Or is one stuck at .2 millivolts? Let me know sometimes a upstream o2 will fail causing fuel to be dumped in but will know for sure after you do this.
Now after that test plug vac line back in and give engine another source of fuel (propane works or a aerosol can of carb cleaner or brake clean) see if fuel trims go richer or if they stay where they're at. Let us know
- jesg45
- jesg45
- Hardtopdr2
Also what was fuel rail rest pressure koeo? 42psi or was it higher after the initial 50-60 psi buildup?
- Hardtopdr2
- jesg45
- Hardtopdr2
- Hardtopdr2
- jesg45
- Hardtopdr2
- jesg45
- Hardtopdr2
You will fry your multimeter checking a live circuit and possibly cook pcm.
- Tutti57
- Thank you received: 254
Engine coolant temp sensor can also cause a rich condition.
Ia there any way the the front and rear o2 harnesses are mixed up? I don't remember your values there but I remember seeing something weird one time that made me think of that.
Timing also comes to mind to me. Especially with recent head work, even though there was a problem before that, you did mention that it seems worse.
Like someone else mentioned, are you able to force the o2 sensor and fuel trims lean if you pull a vacuum line off?
Is there any change if you pinch off the purge valve hose? A stuck open purge will usually cause a lean condition, unless the canister is saturated with fuel.
Just a few more ideas for you to try out before you swap the PCM. I personally wouldn't go there yet. I'm not sure if there are any bulletins addressing this either.
Nissan Technician
