05 mustang 4.0
  • Fastrider750
  • Fastrider750's Avatar Topic Author
6 years 2 months ago #42750 by Fastrider750
05 mustang 4.0 was created by Fastrider750
anyone know of a way to clean the cats (off vehicle) clogged due to manifold vacuum leak at pcv connection (broken orings ) car was driven till it died changed plugs and ff completely fouled all 6 .compression is good fuel and sparkgood inj pulse no flow pulled the 2 front o2s car will run .put them back car starts and dies instantly
6 years 2 months ago #42753 by Hardtopdr2
Replied by Hardtopdr2 on topic 05 mustang 4.0
If its caked on (dry) sodium hydroxide and water solution (draino for plumbing), oven cleaner in the spray can (will need several cans). Let it soak and flush it in forward and reverse flow directions repeat till clean rinse. then repeat two more times with cleaner and rinse till clear. Capture rinsate in plastic bucket and wear elbow length rubber or nitrile gloves and a waterproof apron as sodium hydroxide will desolve flesh if gets on skin and is not immediately washed off.
Time to create page: 0.264 seconds
