Vref circuit
  • seon deone
  • seon deone's Avatar Topic Author
6 years 1 month ago #43079 by seon deone
Vref circuit was created by seon deone
Hi everyone, can anyone help me figure out what would cause a high reading of 5.75 volts on the 5 vref circuit? It's a toyota ecu?
Before I pull my hair out.:pinch:
6 years 1 month ago #43084 by Cheryl
Replied by Cheryl on topic Vref circuit
I’m assuming it doesn’t run?? I’d cut the 5 volt ref wire where you can repair it at the pcm recheck. If it’s the same load test powers and grounds at pcm. I had a 2015 Kia Soul have 8 volts on the reference wire it was a bad ground at the pcm
  • seon deone
6 years 1 month ago #43088 by seon deone
Replied by seon deone on topic Vref circuit
Actually it does run but not well, thanks I will try that.
