2014 Ford Escape SE 1.6L
  • robert.lesaca
  • robert.lesaca's Avatar Topic Author
6 years 1 month ago #43488 by robert.lesaca
2014 Ford Escape SE 1.6L was created by robert.lesaca
This vehicle was towed to my home. Owner complaint was after driving sometime, as he steps on the accel pedal, there is only a high RPM and transmission seem to slip with the vehicle unable to run. He turned off the ignition and waited for a few seconds and it drove fine for a short distance and the same sympton occured. DTC showed a permanent fault P26B7 - engine coolant bypass valve open and a P1299 - cylinder head overtemperature protection active.
I did an initial test fo the coolant bypass valve: KOEO, (1) one wire showed 12.36 V (violet/brown wire) and (2) the other 35.6mv (yellow/gray wire) instead of 12V without being energized...I dont have a wiring diagram and I want to test the control wire at the PCM. Any tips/suggestion is welcomed. Thanks
6 years 1 month ago #43519 by Tyler
Replied by Tyler on topic 2014 Ford Escape SE 1.6L
Sure sounds like that bypass valve is electrically open! :silly: From the description and operation, it sounds like the PCM won't open that bypass until 158 degrees. Ain't nobody got time for that.
I wonder if you connect a test light to B+ and probe the bypass control wire, and hit the KOEO Self-Test, you could get the driver to operate? That'd be a lot faster than waiting for the engine to warm up.
A bidirectional function would (hopefully) do the same thing. If the test light shines, you're good to go with a new bypass valve. B)
6 years 1 month ago #43559 by Matt T
Replied by Matt T on topic 2014 Ford Escape SE 1.6L
I agree with Tyler that a test light would be a worthwhile test. Unplugging the solenoid and putting the light across the terminals might work better?? Then KOEO the light shouldn't be stuck on but might illuminate briefly as a self test. If the wiring to PCM is good that should allow the code to be cleared unless the monitoring is smart enough to measure solenoid resistance.
I don't have a good feeling about this one though. The two P codes seem loosely related to the customer complaint......
  • robert.lesaca
6 years 4 weeks ago #43667 by robert.lesaca
Replied by robert.lesaca on topic 2014 Ford Escape SE 1.6L
unplugging, KOEO, TL (+), probing control wire and performing self test, TL lit confirming driver Ok; likewise voltmeter showed a drop in voltage as driver commanded on. Replaced the bypass valve . out of curiosity, KOEO, voltmeter read 12V on each wire ! This portion of the problem was FIXED.
However test driving it around, shift was still rough and tranny was still slipping. A new code this time showed : (1) P0731 Gear 1 and P0733 Gear 3 incorrect ratio; (2) P0219 engine overspeed condition.
I advised owner to have his tranny checked by a specialist.
As for the bypass valve, this is a FIXED.
6 years 4 weeks ago #43701 by Tyler
Stick a fork in it, 'cause it's done. :silly: Those transmissions are absolute junk.
Thanks for the update. :cheer:
6 years 4 weeks ago #43703 by Matt T
robert.lesaca wrote: Replaced the bypass valve . out of curiosity, KOEO, voltmeter read 12V on each wire !
That's normal for a ground side switched circuit when it's commanded off. With no path to ground there isn't any current flow to cause a voltage drop across the solenoid.
  • robert.lesaca
6 years 3 weeks ago #43717 by robert.lesaca
correct...12V in and 12V out KOEO.
