2002 ram 1500
  • jerry r
  • jerry r's Avatar Topic Author
6 years 1 month ago - 6 years 1 month ago #43617 by jerry r
2002 ram 1500 was created by jerry r
ECT problem gauge reading hot code for ECT circuit high, hooked up scan tool shows -40 shows five volts at signal signal wire jumped signal wire to ground no change. Could it be possibly a bad pcm
Last edit: 6 years 1 month ago by jerry r.
6 years 1 month ago #43618 by Tyler
Replied by Tyler on topic 2002 ram 1500
When you were looking at the scan data for the ECT, were you on the OE side, or Global data?
If OE, then it wouldn't surprise me if that ECT PID defaults to -40 with the ECT circuit code set, despite whatever you may be doing to it with a jumper wire. ;) For fun, try installing the jumper then turning the key off. Leave it off for 5-10 seconds, then turn the key on and clear codes. What code do you now get, and what does the ECT PID say?
  • jerry r
6 years 1 month ago #43619 by jerry r
Replied by jerry r on topic 2002 ram 1500
On global
6 years 1 month ago #43621 by Tyler
jerry r wrote: On global
Good! Global shouldn't be allowing for any substituted value goofiness.
When you installed the jumper on the ECT connector, did the voltage on the signal wire actually go to 0V? As in, could you measure the drop with a DMM? If it did drop, that may be a strike against the PCM. :unsure: If it didn't, the ECT ground may suck. Redo the jumper test with one end on the ECT signal, and the other to B-.
