Starts but dies [FIXED]
9 years 8 months ago #5899 by Tyler
Replied by Tyler on topic Starts but dies
Donnyten wrote:
Noah wrote: As long as the needle is steady and not bouncing or dropping off, the valve train should be fine.
Sorry to hear about the oil leak after all that work! Any ideas?
I hope things aren't warped.. Other than that why else would I still have leaks seeping from the lower intake and headgasket areas? Torqued to spec in correct order including the degree turn at the end
How's the PCV system? With the engine idling, you can put your vacuum gauge on the dipstick tube and check the reading. Should pretty much stay at zero.
Excessive crankcase pressure might cause a lower intake to leak, but not a head gasket...
9 years 8 months ago #5941 by Doc n2mx
Replied by Doc n2mx on topic Starts but dies
Lets think about the need for WOT, to things are going on here air and fuel. I am sure it probably getting air so we need to look at if the air is getting out, you stated that the car was burning coolant, if this is true in time the coolant will damage the cat., thus restrict exhaust. If you are limited in test equipment. You can unhook the cat and start it, if it runs, you know what’s next.
I would test the fuel system, pump pressure and volume. And injector drop test.
Good luck
  • Donnyten
  • Donnyten's Avatar Topic Author
9 years 8 months ago - 9 years 8 months ago #6031 by Donnyten
Replied by Donnyten on topic Starts but dies
Thank you. Problems been solved already. I'll keep that in mind for future reference
Last edit: 9 years 8 months ago by Donnyten.
  • Donnyten
9 years 8 months ago - 9 years 8 months ago #6032 by Donnyten
Replied by Donnyten on topic Starts but dies [FIXED]
I did get an aftermarket (Autozone duralast) PCV valve for 2 bucks which I hear does not compare too manufacturer valves. I think I'm going to go to General Motors soon to pick up a new one
Last edit: 9 years 8 months ago by Noah. Reason: fixed
