10 chevy impala 3.5 starting issue
- bandrauto
5 years 11 months ago - 5 years 9 months ago #44469
by bandrauto
10 chevy impala 3.5 starting issue *FIXED* was created by bandrauto
ive got a 2010 chevy impala 3.5 pulled out of the repo line. dont know any history on it. the issue is, when the ignition switch is put into the run position, the car cranks. had an 08 that the switch was the same. same issue. when looking in the bcm, i can see where the ignition switch location is. it appears correct. there is a yellow wire that is the signal for the starter relay that comes from the pcm and it has voltage on it at all times which is the issue. from my understanding, the bcm sends a starting signal over the comm lines to the ecm which then sends the signal to the starter. starting my diagnostics at the bcm, i removed the acc wire from the ignition switch and it wouldn't crank, so im a little confused, though wondering if it is the pcm.
after looking over it, we put another computer and programmed it. still not start. after tracking down the no start issue, the low line was being pulled down by a couple modules. after finding the ones and disconnecting them, the lan came back up. the TDM was still down, found used and programmed to vehicle. learned key to TDM and the vehicle now starts and drove out of the shop. PHEW.
Last edit: 5 years 9 months ago by bandrauto.
- Hardtopdr2
- Thank you received: 150
5 years 11 months ago - 5 years 11 months ago #44470
by Hardtopdr2
Replied by Hardtopdr2 on topic 10 chevy impala 3.5 starting issue
With some used car dealers they install a gps unit that can dissable starting. Is it still disabling the starter signal?
Last edit: 5 years 11 months ago by Hardtopdr2.
- bandrauto
5 years 11 months ago #44488
by bandrauto
Replied by bandrauto on topic 10 chevy impala 3.5 starting issue
first thing i do with any of these auction cars or any other car lot car is check for any crazy wiring. although this car is really rough, the wiring was clean, nothing added on
5 years 11 months ago #44513
Replied by Tyler on topic 10 chevy impala 3.5 starting issue
Which wire did you remove from the ignition switch to get it to not crank? I like this test, just want to understand exactly what changed.
In the BCM scan data, what does the Power Mode data list have to say about the ignition switch while it's in the run position?
For testing purposes, it might be easier to disconnect the starter S-post wire and wire it to a test light. That way, you can see the light illuminate while you're testing, instead of cranking it multiple times.
- bandrauto
5 years 11 months ago #44777
by bandrauto
there are no addons to the system, ive checked all over.
as for what wire i removed, i do not remember, i would have to go back and look. i pushed the thing back outside to make some money.
good idea about disconnecting the start wire from the starter, i should have thought of that. that would allow me to leave it in the run possition and see if i can get it to quit.
when i check all data on the scanner, it appears that when the ignition switch is in run, it is NOT asking for crank, but when twisted further into the crank position, it says crank.
- Matt T
- Thank you received: 276
5 years 11 months ago #44779
by Matt T
Replied by Matt T on topic 10 chevy impala 3.5 starting issue
Could use a low amp clamp to tell whether the relay control current is flowing thru' the PCM or going somewhere else. Or just cut the wire at the PCM.
- bandrauto
5 years 9 months ago #46032
by bandrauto
car is finally fixed after waiting and waiting for parts and programming
- Cheryl
- Thank you received: 215
5 years 9 months ago #46047
by Cheryl
Replied by Cheryl on topic 10 chevy impala 3.5 starting issue
So what needs programming??
