Re:2012 Nissan Versa CVT unusual speed sensor data
- atikovi
- Matt T
- Thank you received: 276
- Tutti57
- Thank you received: 254
I've got a '14 versa I can check on, not sure if it's the same transmission though, about that one not reading 0mph.
Common wire issues with those are seen after a replacement having to do with that round one not being plugged in all the way. it twists and is weird. There is a special tool for it (that I've never seen be used) but I just put channel locks on it and make sure it's seated. Also there is a sensor on the back and one on the side that easily gets busted off or broken if you're not careful.
Full disclosure, I am not a cvt guy. I've replaced a bunch and know what the death codes look like, but have never rebuilt one or been to any of the Nissan classes yet.
- atikovi
- guafa
- Thank you received: 80
I suggest you to keep an eye not only in sensors but in pressure lines (main, drive pulley and driven pulley). Those codes could be caused not only because of a bad sensor, but because the sensor itself is not detecting "desired speed".
Not an expert at CVT, but I have been playing around a Honda one (trying to program by myself with my own TCM).
Was the earlier CVT giving that same issue?
- Tutti57
- guafa
If I am right, those transmissions can monitor only main pressure line. I mentioned drive/driven pulley because if you loose pressure in any of those lines (which are not monitored), chain instantly loose friction with pulleys.
- atikovi
I did set the fluid level by the book, at the correct temperature and letting the fluid dribble out while running. Scan tool says the G sensor is calibrated and not sure about the relearns. Remember doing something like that with the scan tool but I'd think it would throw a code for that if there was a functional issue related to it.
Going to drive on the highway next and see what happens. What should I be monitoring?
- Tutti57
Do those codes set immediately or do you have to drive it for them to show up?
- atikovi
- Tutti57
- atikovi
- Tutti57
- 93Rubie
- Thank you received: 13
- atikovi
- Tutti57
- atikovi
It's in a canister with a thin o-ring to seal it. Apparently the o-ring got distorted on installation, 15 miles after taking it for a test drive on the highway it stated acting up again and eventually wouldn't move. Large puddle of trans fluid under the car. Fluid leaking from filter housing. Towed it back. Got a new o-ring and was careful to put the filter housing back straight and square and refilled with fluid. Also had to degrease the underside of the car from all the fluid that sprayed back there.
Went for an extended drive yesterday. 55 miles out and 55 mile back. Ran fine. No stored codes. Hoping it was just the connectors at the sensors that I cleaned up was the problem. Will drive some more and see.
