U1013 2014 Focus
  • fahead32
  • fahead32's Avatar Topic Author
5 years 11 months ago #44763 by fahead32
U1013 2014 Focus was created by fahead32
Hi
Looking for some repair procedure for the above code . My 2014 Focus has the Dps6 tranny and it is at the point of no crank no start . The problem started with the usual transmission overheating while driving and slipping gears (slip from driving to nuetral)
After doing my research and some testing , the clutch adjustment test failed .
Long story short , I decided to take a risk and get a TCM module and installed it and now I am getting an U1013 code when I try to program it to the car Cheacked all my powers and grounds and networks signals at TCM harness and all are good. Check AllData and Mitchell , Alldata skips this code and Mitchell is very vague no test procedure.
Anyone can help with info to test and fix this problem it will be welcomed
5 years 11 months ago #44766 by Matt T
Replied by Matt T on topic U1013 2014 Focus
This might help. Lots of TSBs for this thing and might still be an active recall.
www.dtcdecode.com/Ford/U1013
The following user(s) said Thank You: Noah, Paul P.
