Re:Injectors not pulsing
- Kyle55
- Paul P.
- Thank you received: 195
Never stop Learning.
- Paul P.
- Kyle55
- Paul P.
If not, check the CKP signal.
- Kyle55
- Matt T
- Thank you received: 276
Kyle55 wrote: I've narrowed it down to cam sensor on producing 2.55 volts sent to ICM and Ecm.
Took a look at the OE wiring diagram, and attempted to decipher the troubleshooting procedure for P0341.
It appears the ICM should supply 5V to both the CMP signal wire and the PCMs CMP input. The CMP grounds the signal to sensor ground when it triggers. I'd try unplugging the N.E.W. CMP to see if that brings the voltage up. If that doesn't then unplug the PCM and see what if it does.
- Kyle55
- Matt T
What I'd do next is unplug CMP, ICM and PCM then check the ICM to CMP and ICM to PCM signal wires for a high resistance short to ground.
- Kyle55
- chris.campbell
Do you have fuel pressure at the injectors?
What test did you run to determine the injectors weren't firing?
Have you checked ALL powers and grounds at the ECM connector? Easiest way to check that is with a test light. There's a scannerdanner video on that. If you changed the ECM, go back to the original one unless you are sure the original one is bad.
Can you have someone help you get it running off propane long enough to see if your scan tool shows RPM? Some systems may not report RPM to the scan tool during cranking. I haven't worked on a GM of that vintage in a while so I don't know how it would behave.
- chris.campbell
Here's a video from Mr. Danner with specifics.
and please stop throwing parts at it! That's only going to make things harder.
- Tutti57
- Thank you received: 254
It doesn't sound like it, but I wanted to make sure that you were getting the 2.5v at the sensor while cranking it, since that may be accurate for a meter to show on a 5v square wave.
Keep at it and you'll get it sorted out. The help on here is as good as it gets!
- Kyle55
- Kyle55
- johnathon.balderas
- Stay humble and thank God everyday for waking up.
- Kyle55
- Kyle55
- Kyle55
