no spark
  • jockamo
  • jockamo's Avatar Topic Author
5 years 11 months ago #44927 by jockamo
no spark was created by jockamo
My 2009 subaru forester has no spark for several seconds while cranking. It may crank until the battery goes dead or it may start right away.
My question is, what is the sequence of events that will cause the coil to fire?
5 years 11 months ago #44930 by J.D.
Replied by J.D. on topic no spark
First thing that jumps out at me is do you have adequate cranking voltage to sustain a good spark ? ... J.D.
5 years 11 months ago - 5 years 11 months ago #44932 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic no spark
Check the crank sensor output would be my first check followed by using a test light to check power to coil and if it its getting grounded via the ECU
Last edit: 5 years 11 months ago by Andy.MacFadyen.
5 years 11 months ago #44937 by Tutti57
Replied by Tutti57 on topic Re:no spark
Is this a new symptom that it will start sometimes or start after extended cranking? Does the jump make it start everytime still? I was thinking that it only started with the jump on from your other thread. Just want to understand the exact symptoms and know if anything has changed there.
Nissan Tech
5 years 11 months ago #44940 by J.D.
Replied by J.D. on topic Re:no spark
Most often I find these issues are found in the primary side of the ignition due to the low voltage. In the secondary side usually at least a few cylinders will fire. A damaged or misaligned crank sensor or poor connection in that area ? I recall finding one hanging by it's wires ! ...J.D.
5 years 11 months ago - 5 years 11 months ago #44941 by J.D.
Last edit: 5 years 11 months ago by J.D..
