2011 BMW 535i 3.0 Rough Idle Stalling
- Mikeyb742
5 years 10 months ago - 5 years 10 months ago #45015
by Mikeyb742
2011 BMW 535i 3.0 Rough Idle Stalling was created by Mikeyb742
Hello there everyone. I just replaced the valve cover and gasket as one together OE and now have rough idle and stalling. Also crazy vacuum you can feel and hear when you remove oil fill cap. checked the vacuum lines and hoses and the connector on top of motor that is in middle of valve cover and heard air so i fixed that car ran great on 20 min test drive and no issues. sat outside for about 4hrs and when i went to start to bring in shop it stalled twice and then ran ok coming in shop. any ideas or run ins with this issue too? Thank You all so much and Merry Christmas!!!!
Last edit: 5 years 10 months ago by Mikeyb742.
- spit64
- Thank you received: 22
5 years 10 months ago #45443
by spit64
Replied by spit64 on topic 2011 BMW 535i 3.0 Rough Idle Stalling
are there any whistling sound my first thought is the PCV valve that is in the valve cover it is a new one but can it be bad
- Tutti57
- Thank you received: 254
5 years 10 months ago #45505
by Tutti57
Replied by Tutti57 on topic 2011 BMW 535i 3.0 Rough Idle Stalling
You can check the fuel trims at idle and held at like 2500 rpms to see if it's a vacuum leak, which is likely is because of the recent repair. I'd try using propane or spraying brake cleaner on suspected spots while watching stft for changes.
Does the intake have to come off for this job? Is there a hidden vacuum line you might have forgotten to put back in?
- Mikeyb742
5 years 10 months ago #45636
by Mikeyb742
Replied by Mikeyb742 on topic 2011 BMW 535i 3.0 Rough Idle Stalling
got it all back together found it was a Faulty valve cover and had to warranty for another which then had a seal leak on vacuum pump going into valve cover lol. all good now thank you all
Time to create page: 0.325 seconds
