What are the g/s at idle for Versa 2018
  • Jayjay100396
  • Jayjay100396's Avatar Topic Author
5 years 10 months ago #45069 by Jayjay100396
What are the g/s at idle for Versa 2018 was created by Jayjay100396
Im work on 2018 N Versa with code PO101 I’m not sure what the maf. g/s should be at idle , my (snap on Modis edge) info Specifies 4-7 g/s at idle I have 1.8 g/s. @ idle and 5.7 g/s @ 2.500 rpm so my maf is bad y/n
5 years 10 months ago #45072 by Matronix
Replied by Matronix on topic What are the g/s at idle for Versa 2018
You can calculate your MAF expected / normal with tools like these www.autotech.network/calculators/maf-calculator
but 1.x seems very low. However it does not need to indicate a bad MAF sensor, but can also mean your air is drawn from another spot after it's measured by the MAF (a leak in a vacuum situation if you wish)
Time to create page: 0.267 seconds
